adjusted timing?
Old Mar 2, 2006 | 04:55 PM
da boss's Avatar
da boss
Default adjusted timing?
Why would you want to adjust your timing? Does increase horsepower or maybe MPG? Just wondering thanks
Old Mar 2, 2006 | 04:57 PM
blackbetty01's Avatar
blackbetty01
Default RE: adjusted timing?
I'm getting it done as soon as I get my SCT Tuner, I read it can increase HP by as much as 15HP. Typically a safe adjustment brings about 7HP. Hopefully mingrey01 will chime in on this one since he already has his timing advanced to I THINK 16*. Not sure on that one though.
Old Mar 2, 2006 | 05:05 PM
da boss's Avatar
da boss
so with adjusted timing and the tuner you should have around a 30 hp increase or at least around that right?
Old Mar 2, 2006 | 05:10 PM
Tim37's Avatar
Tim37
ORIGINAL: da boss
no you can only adjust the timing a certian amount you can either use a tuner or one of the timing adjusters but you don't need both. and it really depends on the car and engine when it comes to how much and and up or down.
Old Mar 2, 2006 | 05:43 PM
blackbetty01
ORIGINAL: Tim37
Exactly, the SCT should advance the timing a little, usually people have that done when they say they have a 91 octane tune. Without running a higher octane you would hear the engine pinging.
Old Mar 2, 2006 | 06:17 PM
StangChik's Avatar
StangChik
ok so what should you adjust your timing to. would this make a difference on my car?
Old Mar 2, 2006 | 06:21 PM
SOHCtimes2's Avatar
SOHCtimes2
ORIGINAL: StangChik
Clicky Click! Check out this link...MM&FF gained 6RWHP and 15RWTQ just by adjusting the timing forward by 5 degrees. The tests are done on an Automatic '01 GT.
Old Mar 2, 2006 | 08:50 PM
JonBeast's Avatar
JonBeast
Moderator
I have my T/A set at 16*
Edit: On 93 octane
Old Mar 2, 2006 | 09:10 PM
bb1211's Avatar
bb1211
it also depends on what grade gas you are using. if you advance it too much you will lose power.
Old Mar 2, 2006 | 09:31 PM
JoeyD's Avatar
JoeyD
^I use 91 Oct.
So with the DIABLO tuner...
It goes up to 10 Degrees... so if I took it up to 10Degrees... that would mean I advanced the timing 20Degrees?
So if I want it at 15* advanced... on the diablo I put it at 5* right?
Pyrate Dave
Sep 10, 2015 07:30 PM
DoctorScary
Sep 9, 2015 07:53 AM
RWHEELS
Sep 5, 2015 03:42 PM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
