X pipes
Old Feb 17, 2004 | 02:30 AM
NOTUAGN's Avatar
NOTUAGN
Default X pipes
Can someone explain to me what the x-pipes exactly do and do they really add up to 20HP??
If so i'm off to e-bay and ordering one right away!
Which ones are good,there's bassani for like 200$ or UPR for arround 130 or the mac ones....
which one do you guys have or would go for?
Old Feb 17, 2004 | 03:05 AM
Razor19's Avatar
Razor19
Default RE: X pipes
I dont think it will add 20 hp with just the x-pipe. I know for sure it wont add 20 rwhp with just the xpipe. xpipes just help your air flow smoother and quicker through your exhaust. I would say the best is Bassani and if u can get that for $200 then take it cause that is a really good deal.
Old Feb 17, 2004 | 05:10 AM
GSXRIntensity's Avatar
GSXRIntensity
Default RE: X pipes
X-pipes are better mid-pipes for gaining horsepower. You will NOT gain 20hp from just an x-pipe though. You'd be smart to cut that # in 1/2. Compared to an h-pipe, the exhaust to more evenly distributed. You will loose a little lowend compared to the h-pipe, but you will have more on top.
If you want a quality x-pipe stay away from UPR! Look at Dr. Gas (the originator), Bassani, or Magnaflow for x-pipes. You will probably gain most of your hp from Dr. Gas, becaues they place their bends closest to the headers which allows for a couple ponies. I don't know how many more exactly, & I went w/Bassani anyway, but I hope this helps.
Old Feb 17, 2004 | 07:30 PM
JHonor's Avatar
JHonor
Default RE: X pipes
I went with the Magnaflow; it's a good one. I didn't notice any loss in bottom end, and the mid to top end pull was good. Not going to get 20hp from (unless perhaps you're supercharged), but the power is definitely there. Springfield Motorsport (they've done some of my work) dynoed a stock 99 GT with a Magnaflow catted x-pipe and catback with a 13.4rwhp and 9lb/ft rwtq gain. So long story short, you feel it, but it's not that much.
Old Feb 17, 2004 | 11:05 PM
04ShakinSteed's Avatar
04ShakinSteed
I ♥ Acer
Default RE: X pipes
You won't get 20 HP from an X-pipe. You will gain about 10-13 hp maybe. Go with a real designed X-pipe. MagnaFlow is one of the best. I've heard good things about Dr. Gas too.
Old Feb 18, 2004 | 12:50 AM
GSXRIntensity
Default RE: X pipes
ORIGINAL: JHonor
You missunderstand me. The x-pipe does not have the lowend a performance h-pipe does. Anything you bolt on will be an improvement over the stock h-pipe.
ak98
Feb 18, 2023 08:36 AM
Sep 24, 2015 09:18 PM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
wawagner82
Sep 13, 2015 09:02 AM
