Need some quick help guys
Old Mar 12, 2006 | 10:06 AM
GTkyle's Avatar
GTkyle
Default Need some quick help guys
Hey all i recently purchased a '96 mstang gt witht he 4.6l. Due to an intake and entire stainless exhaust, the car is running lean. It has all stock componets, but i am wondering if a JET power tuner will fix my air/fuel ratio? The MAF is maxxed out, and i want to avoid getting another one and 24lb injectors. I need some quick help guys, i'm running up to Summit today and need to know if i absolutely have to get a MAF or not. Thanks guys
Old Mar 12, 2006 | 10:14 AM
beheivjer's Avatar
beheivjer
Default RE: Need some quick help guys
the maf should be maxed if it is stock with an intake. there should be alot of room left are you throwing a code?
Old Mar 12, 2006 | 10:19 AM
GTkyle's Avatar
GTkyle
Nope, no code, she passed e-check last week. The car shudders when you give it 1/4+ throttle, it is running lean like i said. The JET tuner is supposed to check and modify ignition timing, air/fuel, and shift firmness and oints, thats why i need to know if i can just get away with the tuner.
Old Mar 12, 2006 | 10:22 AM
GTkyle's Avatar
GTkyle
OH forgot to say, before going to echeck i put on some catco cats, which gave it a little backpressure and did actually make huge improvements over when i drove it home. It did just have an SLP x pipe with the cats removed, and it shuttered and jerked real badly then.
Old Mar 12, 2006 | 10:25 AM
beheivjer's Avatar
beheivjer
sure go ahead work in the dark if you want. I just dont understand how on a stock engine you are lean. if it is lean and the engine knows it will throw a code. seriously i think you have a different problem than just tring to shange the fuel curves. and a jet is the cheapest actual tuner out there. there are others that give you even more control. like i said i dont think playing with the computer is the best way to fix your problem on a stock engine no real mods on it.
Old Mar 12, 2006 | 10:28 AM
GTkyle's Avatar
GTkyle
Well....Could it possibly be my spark plugs/ wires? I took a couple out and they had a clean, brown burn on them, but the electrodes were sort of wore down....but nobody around carries the motorcraft AWSF-32PP or 32P for that matter. What other kinds of plugs does the 4.6 like?
Old Mar 12, 2006 | 10:38 AM
beheivjer's Avatar
beheivjer
tr55 ngk plugs but the motorcraft changed to the old stock number it is now like a sp429 or something like that. sounds like the a/f is right by the way the plugs are burning. all of a sudden start doing this?
Old Mar 12, 2006 | 10:42 AM
GTkyle's Avatar
GTkyle
Well this is the way i bought it. The spark plug wires are the ones that came on from the factory, they are dated 1996. I know the exhaust has been on there for a while because the stainless tips (slp) have a decent amount of carbon on them. I just don't know if they guy put the intake on, and it started acting up, so then he wanted to get rid of it or what.
Old Mar 12, 2006 | 10:51 AM
beheivjer's Avatar
beheivjer
is the fuel pressures good? thats what it soulds like to me a fuel pump problem. might want to check the pressure on the rail. you should have like 30 at idle and 35 at accel. sounds like you are a little low.
Old Mar 12, 2006 | 10:53 AM
GTkyle's Avatar
GTkyle
well without spending 100 bucks on a regulator, how can i check?
