finally broke into the 12's
finally hit the 12's....12.943 to be exact. First time trying the nitrous and it made a world of difference, before i was running about 13.9 on average....so it dropped a full second. I could really feel the car pull like a mother when the car hit 3000 rpms(thats what the window switch was set for). The bottle pressure was only at 600...so im sure i could get it a little quicker. I also had a question for anyone with a NOS bottle heater.....how long does it normally take for it to heat up? I had it on for like an hour and it seemed to stay the same pressure.
[IMG]local://upfiles/22339/5E034BE329D84509A2704742423AACEA.jpg[/IMG]
RE: finally broke into the 12's
It usually takes a little while for the bottle to heat up depending on outside temperature. It helps a lot if you take the heat sensor out because it will heat it up quiker but you have to watch it and put it back in once it gets to the temp you want if you dont watch the bottle pressure it will sky rocket. I took mine off once and forgot my bottle pressure was up around 1700 psi. thank god I didnt spray it at those pressures. Hey what kind of window switch are you runing is it digital or ran off of rpm pills? I am wanting to get one. Did you have to run a tach adapter for it?
ORIGINAL: stangerism96
ORIGINAL: 03sonicgt
What kind of shot did you run?
ORIGINAL: mustangsel
xkon where from in Jersey ?
