basic ?’s
Old Feb 15, 2003 | 03:46 PM
92notch50Liter's Avatar
92notch50Liter
Default basic ?’s
ive been told to get a camshaft and a new timing chain will that help make my engine stronger for a future supercharger? what kind of cam should i get? If i get some eibachs do i have to replace the struts? i want to make my engine stronger and add horsepower what should i do. I ran a 15.1 at fun ford weekend and i had headers and gears. Im going again an i want to get in the 13's to 12's. i have an automatic and i wanna know the best way to shift on the dragway.It is an aod without shiftkit. thanks joey
Old Feb 15, 2003 | 07:17 PM
spike306's Avatar
spike306
Default basic ?’s
under-drive pulleys are cheap, easy to install, and will give you 12-15 hp. but you will really feel it on your launches!!the e-cam, and the f-cam (e303; f303) are both great cams, and very enexpensive. definetly improve your breathing system by using a bbk cold air kit mixed with a 70mm throttle body. it wouldn't hurt to upgrade your mass air. you won't spend a lot doing this, but you won't be in the 12's either. to do that, you need to get a better upper and lower intake, and better heads. or just save up to get a t-trim supercharger!!!! good luck joy!!
Old Feb 15, 2003 | 08:16 PM
noslow50's Avatar
noslow50
I ♥ Acer
Default basic ?’s
i duno about that e or f cam.. i know they r good but my frined had an e cam in his 86 and he had the cai headers and t/body and mass air conv. and with that cam the car ran like sh*t.. ended up being that the cam was too big for the car... he has recently put the stocker back in and runs ten times better..
Old Feb 15, 2003 | 08:21 PM
spike306's Avatar
spike306
Default basic ?’s
your right, w/o modified heads it will run like sh*t. i'm glad you thought of that !!!
Old Feb 15, 2003 | 08:24 PM
noslow50's Avatar
noslow50
I ♥ Acer
Default basic ?’s
lol my friend has a 64 comet with a 5.0 outta a 92 stang and he has the b cam... but since he jsut got his new edelbrock heads he wants to get the ecam off my other buddy... kinda find it funny..
Old Feb 18, 2003 | 03:16 PM
92notch50Liter
Default basic ?’s
Ive been hearing about these things called 1.72 Roller Rockers. how much horsepower will it give me onj stock engine but i have a cold air intake and headers. what the hell are these Roller Rockers and what is a good kind? where could i buy them? are they hard to install?
Old Feb 18, 2003 | 07:27 PM
lloydchristmas's Avatar
lloydchristmas
Default basic ?’s
Well said spike. I run the E and havent had a problem yet
E is a good blower cam but with out the blower or juice the b is more than sufficient
Old Feb 18, 2003 | 10:02 PM
spike306's Avatar
spike306
Default basic ?’s
i've heard that about the b-cam, could you explain though, i'm curious
Old Feb 18, 2003 | 11:46 PM
lloydchristmas
Default basic ?’s
The E is only a tiny bit different when you read thespecs. but it sounds like an animal even in a basically stock motor. (at least mine did) 90% of the 5.0s around here run a B. The E just seems to gel with blown or nitrous motors. And its emissions legal. (go figure) Some say the E too much cam but it worked out well for me.
Old Feb 19, 2003 | 12:04 AM
spike306's Avatar
spike306
Default basic ?’s
very interesting!!!!
