vortech update
Old Mar 31, 2006 | 01:10 PM
mustang_montana's Avatar
mustang_montana
Default vortech update
finished putting my gas tank back in with the new pump. funny story actually. went well at first, but i broke the fuel pump assembly fuel line while removing the lines...rusty as hell and just snapped. so i bought a new one, by the way anyone need a new stock fuel pump? 88lph?, anyway so i got that then opend up my walbro fuel pump kit. they sent me the right install kit, but the wrong friggin pump! so i overnighted the right one and got that a day later, so now i have 3 fuel pumps lying around. my old stock one, my new stock one that came with the new assembly, and some random walbro one. now i just gotta figure out how to wire the battery relocation kit, and loop the belt over the new tensioner. oh yeah and md still hasnt given me word on my tune. how long do those usually take? i just needed something quick, i could really use it by saturday.
Old Mar 31, 2006 | 01:17 PM
96cobra10101's Avatar
96cobra10101
Default RE: vortech update
I ditched the tune that they supplied with my sc and went to a local shop and did a Diablo chip and they have a dyno.
Old Mar 31, 2006 | 01:51 PM
mustang_montana
thats what im doing but i need a tune to get me to the dyno. i might just have it towed if they are gonna take their sweet time on my tune.
Old Mar 31, 2006 | 01:53 PM
96cobra10101
Did you change the injectors? How about your mass air?
Old Mar 31, 2006 | 02:00 PM
mustang_montana
yeah 255lph fuel pump 42# injectors 90mm maf
Old Mar 31, 2006 | 02:02 PM
96cobra10101
Get ready to be fast.
Old Mar 31, 2006 | 02:04 PM
ZW99GT's Avatar
ZW99GT
Well since the vortech doesnt creat boost at all rpms, cant you just stay out of it to the shop???? You wont be making squat for boost if you keep it 2-2.5krpms will you????
Old Mar 31, 2006 | 02:27 PM
96cobra10101
The car is going run totally different with the injectors. In fact, you will be lucky if it runs at all. Staying out of boost has nothing to do with it now. You have a dif mass air, fuel delivery and injectors, plus vacuum and boost. The stock chip is going to going into default and the check engine light will come on. If you can drive it, which I doubt you will, you may foul some plugs. By the way, did you put in some NGK's? Also, I am not sure about the 2V, but I have IMRC's, the bearings leaked from the boost and vacuum causing havoc with the engine do to air fuel not being right. I modded them, removing the valves and sealing the ends. New racing ones cost about 300 and you need 2 of them. I had a local shop burn my chip so I could limp it down there and set it up correctly. I have done more work so I need to dyno and burn again, but since I have done a few more things and need another run.
Old Apr 1, 2006 | 01:10 AM
mustang_montana
i havent changed the plugs yet, but definetly will. i havent even got the bypass valves hooked up yet, im mostly just waiting around for the new tune. and running it without the tune would be suicide, the most ill be doing is turning the key on so i can see if the pump is running, and setup the intercooler fluids/pump.
Old Apr 1, 2006 | 03:18 AM
96cobra10101
Sounds like you'll have a beast. Did you do any other drive train work?
