squeaky back
Old Apr 1, 2006 | 08:14 PM
Smooth_J's Avatar
Smooth_J
Default squeaky back
The back of my car makes some noises when going over bumps, it sounds like a squeak, but its not that high pitched. I have no idea when the back shocks/quads have been replaced so I guess it could be those. Any ideas?
Old Apr 1, 2006 | 08:32 PM
NaplesFL11GT's Avatar
NaplesFL11GT
Default RE: squeaky back
Mine does this too when I go over a speed bump or sometimes making a turn. Hope someone can chime in on this because I would like to know as well.
Old Apr 1, 2006 | 08:39 PM
sprostang's Avatar
sprostang
I ♥ Acer
I had the same issue. Turned out to be my e-brake clips. Put some grease on them and the squeak was gone.
Old Apr 1, 2006 | 08:41 PM
LazrRd00GT's Avatar
LazrRd00GT
it sounds like the shocks, try pushing on one of the corners of the car and if it bounces up and down more than 2-3 times before stopping than it is the shocks, replace them. I have a similar problem when holding the brakes and drifting forward slowly but thats it, i used to have the same issue but i replaced the shocks/struts and springs and have had no problems since. Oh and Naples... in your mods list you said "2 cats instead of 4" Mustangs dont have "4" cats, they only have 2, there are 2 resonators behind the cats, and all that the resonators do is help produce a better exhaust note.
Old Apr 1, 2006 | 09:12 PM
Smooth_J's Avatar
Smooth_J
ORIGINAL: sprostang
Where is that?
Old Apr 1, 2006 | 09:13 PM
Smooth_J's Avatar
Smooth_J
ORIGINAL: LazrRd00GT
Tried it, and 1 bounce - but I hear that squeak
Old Apr 1, 2006 | 09:33 PM
sprostang's Avatar
sprostang
I ♥ Acer
ORIGINAL: Smooth_J
ORIGINAL: sprostang
Where is that?
Look right in front of the rear wheels. You will see a cable on each side going to your rear brakes. Lube the clips you see that holds those cables to the frame. Hopefully that works.
Old Apr 1, 2006 | 10:12 PM
04BlueGT's Avatar
04BlueGT
Besides the brake clips, if you have after market control arms, you may need to grease them. I'm told that they raise hell when dry.
Old Apr 1, 2006 | 10:30 PM
Smooth_J's Avatar
Smooth_J
ORIGINAL: sprostang
What is a good lube to use?
Old Apr 1, 2006 | 10:36 PM
sprostang's Avatar
sprostang
I ♥ Acer
ORIGINAL: Smooth_J
ORIGINAL: sprostang
Any kind of grease will be fine. I have a tube of mobil 1 in my grease gun and thats what I used.
