What is the best lowering springs?
Old Apr 15, 2006 | 01:52 PM
coacholy's Avatar
coacholy
Default What is the best lowering springs?
I have a 2001 mustang gt and want to lower it. What is the best springs out there? I want to improve the ride or atleast maintain what I have. I don't want it stiffer. Do you have to use the camber adjustment plates? Does putting shock/struts really improve the ride over factory? If so, what brand?
Old Apr 17, 2006 | 08:41 PM
coacholy's Avatar
coacholy
Default RE: What is the best lowering springs?
ttt
Old Apr 17, 2006 | 08:43 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
ford B spring were the softest springs I found when searching, and they are amongst the cheapest too. if you go more than 1.5 inches, you probably will need c/c plates. you own't need the c/c's with any of the ford racing springs.
Old Apr 17, 2006 | 09:13 PM
Flyingmau5's Avatar
Flyingmau5
it really depends on how much you want to lower your stang... anything beyond 1.5" of lowering you will need cc plates and maybe some new sets of shocks/struts. eibach pro kit is pretty good for anything smaller than a 1.5" drop...
Old Apr 17, 2006 | 09:15 PM
Master's Avatar
Master
if you just looking to lower it get the 1.5 drop from eibach pro kit
Old Apr 17, 2006 | 09:31 PM
Fryguy22's Avatar
Fryguy22
eibach pro kit plus. You get the pro kit springs, shocks, struts, front anti sway bar, rear anti sway bar. All for about 800.
Old Apr 17, 2006 | 09:38 PM
mself52's Avatar
mself52
with ford B springs will i scrape with longtube headers and o/r x pipe?
Old Apr 17, 2006 | 09:42 PM
Fryguy22's Avatar
Fryguy22
If you go over speedbumps fast you will. Just go over bumps sideways and you should be fine.
Old Apr 17, 2006 | 09:45 PM
mself52's Avatar
mself52
but you definetly dont want sportlines with LT's correct? and which would handle better C or B springs? i know the B will ride more comfortable but which for handling and launching better....
Old Apr 17, 2006 | 09:53 PM
jlong00's Avatar
jlong00
The C are the stiffest (not a noticeably harsher ride IMO either), along with the most popular. You can't beat the springs for $130 - FRPP all the way! [8D]
