bigger injectors
Well I think I'm about to run out of bolt-ons. I think all I have left is a plenum and tb. my questions are what size are the stock fuel injectors? are there any other benefits other than the obvious one? and what all to I need to upgrade go with bigger injectors? are there any suggestions as to what i should do besides this? thanks for the advice.
Justin
Justin
Your car came with 19# stock. I would recommend a 75mm tb/plenum and 24# injectors with a match tuned 85mm MAF. Ebay has the new Pro M MAFs for $280 or so and you can get them programed for whatever injector you need. I think seller "coolblueperformance" sells them. Anyway, you may even look at 30#. Code is the N/A king and is running 30# with more done than you so far, so I'd think 24# would work well.
Well as you guys have probably guessed i bought the car with all the mods but the pullies and CAI. Needless to say I've learned a lot in the year that I've owned the car. As far as running on a stock TB, plenum, and injectors that's part of why I asked. As I learn more, more questions come up. Anyways, sometimes I feel some hesitation but I don't know how it felt before the head/cam work. Will engine response smooth out after the mods?
