Sway Bar/Control Arm Issues
Old Apr 28, 2006 | 02:16 AM
Dragon02GT's Avatar
Dragon02GT
Default Sway Bar/Control Arm Issues
Ok, so I installed my Upper and Lower Granatelli CA's today. When putting the sway bar back on the lower CA's I had to bend the sh*t out of it to get it to fit between the two conrtol arms. I finally got it to work, but now my sway bar hangs to low. It doesn't look anything like it used to. You can tell it is slightly flexed inward to fit in between the CA's. Does anyone else have or had this problem when they were installing their CA's. I wnet over everythin in the suspension and can't see how I could've screwed it up. I would post some pics so you guys know what I mean but it is late, about midnight. Please let me know if any of you have seen this before.
Old Apr 29, 2006 | 08:57 PM
Dragon02GT's Avatar
Dragon02GT
Default RE: Sway Bar/Control Arm Issues
Ok, so I got the sway bar installed the correct way. Reversed the blt plates and installed it onthe outside of the CA's. It still hangs rather low. Anyone else seem to think it hangs low with the Granatelli CA's.
Old Apr 29, 2006 | 10:37 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: Dragon02GT
yup
Old Apr 29, 2006 | 11:08 PM
04BlueGT's Avatar
04BlueGT
Exactly. It hangs under the axle, so it will travel with it. Don't worry, you won't drag it over speed bumps.
Old Apr 30, 2006 | 12:13 AM
Dragon02GT's Avatar
Dragon02GT
Thanks guys. Its always good to know I didn't F anything up.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
guitarman376
Oct 11, 2015 01:47 AM
Sep 16, 2015 07:53 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
