Idle is flickering...
Old Apr 28, 2006 | 11:18 PM
meebix's Avatar
meebix
Default Idle is flickering...
Don't ask me why, this might be completely normal and I am just retarded, but ever since my full exhaust went in I am starting to notice a flickering idle. Like I said it may be just because I can actually hear the car and its a lot louder at idle now, so this may be normal and I am just noticing it now, but bare with me
When my car is idling it idles at about 1 grand. However every I would say 20 seconds the engine kicks into another mode almost, then for about 5 seconds it will idle at about 1400 and then go back to 1 grand and repeat the cycle while the car is idling. Then at points in time for instance when I let the clutch out and put it in nuetral at a stop light or something... Not ALL the time, but something, it like completely misfires like the engine is about to stall and then I start to hear the idle again. It sounds like when a car has cams, in between the looping, except I don't have cams, lol.
Let me know if Im retarded or if they might be something wrong...
Old Apr 28, 2006 | 11:28 PM
red2k1gt's Avatar
red2k1gt
Default RE: Idle is flickering...
thats kind of a high idle to begin with, mine idles at around 700 rpms. Clean your IAC recently?
Old Apr 28, 2006 | 11:29 PM
meebix's Avatar
meebix
Nah I havent cleaned it. I will get around to it soon though, I thought that might be part of the problem.
Soap on water to clean it or what? I think thats what Ive heard...
Old Apr 29, 2006 | 09:04 PM
97targa's Avatar
97targa
I Don't think it's your AIC valve. If your idle is fluctuating it's most likely a bad TPS sensor. Check the voltage
bottom and midle should read .4-1.0 volts with ign. on but not started
top and middle sould read 4-5 volts with throttle wide open. Again don't start car just turn ign. on
Old Apr 29, 2006 | 10:15 PM
Davojan59's Avatar
Davojan59
hmm....mine idles at 1000 solid when its warmed up...but thats cause it was tuned that way....its probly the tps
Old Apr 30, 2006 | 04:17 AM
monkeydude3's Avatar
monkeydude3
it sounds like the TPS, or possibly even the MAF. I worked on a car that exibited similar symptoms and it ended up having a gaping hole in the intake tube
Old Apr 30, 2006 | 04:26 AM
Dan04COBRA's Avatar
Dan04COBRA
Could be TPS/IAC and maybe even the MAF, but very unlikely.
Since you mentioned it showed up after your LT/Mid-pipe install, did you use a tuner to shut off your MIL's or did you use MIL Eliminators? If you used MIL Eliminators like I did on my 02 GT, I'd put money on them failing very shortly and that would be the cause of your jumpy idle. Do your RPM's hang funny at all when driving or downshifting?
I'll never waste my time with MIL's again or an O/R mid-pipe again, just for those reasons.
Old Apr 30, 2006 | 04:29 AM
SXGT's Avatar
SXGT
idle in Nutral and Idle in gear are very different. My Auto idles at 900 in park and 600 in Gear. anthing other 1000 should be looked at.
Old Apr 30, 2006 | 04:31 AM
93BlackNotch's Avatar
93BlackNotch
If I was you, I would take it some where and have it looked at... The fact that you asked if you should clean you IAC with soap and water makes me believe that your mechanical ablities might not be up to par....
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
MacSerio
Sep 27, 2015 01:05 PM
