Spring isolators
Old May 16, 2006 | 05:46 PM
04DSGB's Avatar
04DSGB
Default Spring isolators
Do you have to install the spring isolators when doing lowering springs? I have the FRPP C springs but want my car dropped as much as possible with these springs. Will I run into any problems?
04 Mustang GT 5 speed
SLP LMII catback
K&N Filter (air silencer removed)
4.10s
Old May 16, 2006 | 05:52 PM
mself52's Avatar
mself52
Default RE: Spring isolators
free up cuz id like to know also i just bought h&r super sport springs and steeda caster camber plates is there anything else id need?
Old May 16, 2006 | 06:05 PM
04DSGB's Avatar
04DSGB
Anyone??? I want to install thease biotches tonight and need advice. How much lower will my car be W/O the isolators?
Old May 16, 2006 | 07:47 PM
nopropslaw's Avatar
nopropslaw
without the stock rubber isolators I would say you gain an extra 1/8 inch which isn't much...Not a huge difference but if you are tryiing to go low then take them out. Those don't do much anyways. I bought some sportlines with some polyurethane spring isolators. Sportlines are supposed to drop 2 inch, the isolators took about 1/4 inch (they are thicker and stronger than the stock ones)...So I am at about 1.75 inch drop..Just for reference so you know what you will be looking for...
Old May 16, 2006 | 07:53 PM
MustangChris04's Avatar
MustangChris04
if you take them out then your springs are going to squeek.
Old May 16, 2006 | 07:56 PM
grabbem88's Avatar
grabbem88
without spring isolators you will increase the chance of spring walk....which means springs can pop out,and break shocks struts...severe damage
Old May 16, 2006 | 08:31 PM
dvs_03gt's Avatar
dvs_03gt
so especially with sportlines u should use the isolators? would u suggest using the same stock ones or going with some new ones.. from like stangsusp.
Old May 16, 2006 | 08:33 PM
grabbem88's Avatar
grabbem88
depends if they cracked or not...i think a new set for mine was 58 bucks front to back...might be cheaper...it was awhile ago..
Old May 16, 2006 | 09:56 PM
SOHCtimes2's Avatar
SOHCtimes2
I left the lower isolators out on the front...but I plan to switch to coilovers in a month or so.
Old May 30, 2006 | 01:08 AM
Quicktime_GT's Avatar
Quicktime_GT
I think they look better left out on the front.... lowers the front an extra quarter inch i think.. I think it gives a better stance.. its noticable
