Post TB + Plenum Install Question
Alright guys, got the BBK plenum + tb installed, everything seems good. i reused the old TPS as i was able to get it off with a impact driver, and didnt receive any new TPS bolts with my kit. didnt notice any CELs either.
however, the idle is horrible. it normally idled around 500, and it still does, but it burbles real bad. the tach bounces off/around 500. also, when coming back down, it 'bucks' a bit when coming back past 1k. that is REAL annoying, and i hope its not messing with the tranny at all. any idea what is causing this and what I might be able to do to fix it?
if it helps, the car is an auto, and i didnt disconnect the battery before installing the unit. should i be checking the TPS voltage or messing around with the IAC? any help would be appreciated.
yeah, seems bad just at idle... seems to ride alright, except for the 'bucking' around 1k. i didnt take a real good look for that tho, ill have to check that tomorrow as well.
ORIGINAL: 03sonicgt
Did you disconnect the battery while installing it???
