Check Engine Light
ORIGINAL: USAMuscle
Since you dropped it, wouldn't that be the first place you look?
I think I found the answer and just in case this happens to someone else and does a search they’ll find it here.
PO171 is Lean on bank one. (Driver Side)
PO174 is Lean on bank two. (Passenger Side)
Bank one is on the driver side and Bank two is on the passenger side right? Correct me if I’m wrong. So if I’m only getting PO174 and I’m pretty sure it has to do with a bad O2 sensor wouldn’t that relate to the passenger side O2 sensor. What do some of the more knowledgeable people in here think on that, I’m just making an assumption and hopping I’m right.
