Towing questions!!!!
Has anyone pulled a Jet Ski behind their Stang before. I have a chance to get a 2000 Sea Doo GTX for around $3000. and it matches the color of my car. Im not sure of the towing capacity our Stangs can handle. My next question is, will I be able to pull a 600lb. Sea Doo out of the water with wet back tires. I have an auto so that will make it somewhat easier.. Any info would be great!!
The towing capacity is rated really low for the stangs. You've got a high torque vehicle made to race off the line
It should be able to tow it, I wouldn't feel safe pulling it out of the water with the stang though. Depends on the incline. It's not something I personally would do either way, but I think the stang has enough towing power to haul it around.
the only problem is at least with my car/tires when they get wet they have noooooo traction
but i don't see how a torquey V8 would have a problem with those. Let alone an automatic. I have always been told that if you are gonna do a lot of towing, an auto is better than a manual because the hydraulic trans can absorb more heat while giving out good pulling torque better than a slipping clutch off the line.
iv put a hitch on a buick le sabre before, didnt ask what it was for, but a few months later im pretty sure I saw the same one pulling a boat, if it wasnt the same one it was one just like it.
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
