O/R X-pipe Problem
Old May 31, 2006 | 02:19 PM
BowlerGT's Avatar
BowlerGT
Default O/R X-pipe Problem
I have a 2000 GT and bought a pacesetter O/R Pipe (guess you get what you pay for) first a manifold bolt broke off and it was leaking bad, took it to an exhaust shop they had to cut the pipe and reweld it to make it fit on the driver side ($40) but it still sounds like a modified race car at a racetrack, I think the passenger side is still leaking, I tightened the bolts best I could, anything else I can do to fix it before I have to take it back to the exhaust shop
Old May 31, 2006 | 03:09 PM
jpmustanggt's Avatar
jpmustanggt
Default RE: O/R X-pipe Problem
What exactly does it sound like?
Old May 31, 2006 | 03:22 PM
d3mon's Avatar
d3mon
do you have a cat back or just the x pipe, i'm saying this cuz i installed the x with my stock mufllers and it rattled many times i thought it was a leak but wasn't, not a pretty sound but everything sounded good when i put my cat-back on
Old May 31, 2006 | 03:27 PM
BowlerGT's Avatar
BowlerGT
It has the catback also, its all bolted up i think its just leaking on the passanger side
Old May 31, 2006 | 04:13 PM
d3mon's Avatar
d3mon
ORIGINAL: BowlerGT
stock cat back or aftermarket???
Old May 31, 2006 | 05:27 PM
BowlerGT's Avatar
BowlerGT
Well I just had new mufflers and tips put on
Old May 31, 2006 | 07:21 PM
d3mon's Avatar
d3mon
well check the fitment, i just remember that i had a similar problem also, it was in the driver's side though, i replaced my stock pipe with an bbk x pipe, and one of the bolts on the drivers side header made a big gap between the header and the pipe, my friend (mechanic) tried to get that bolt off but it was a bitch, we tried gaskets and everything but kept leaking so i had to take it to a mufler shop and they took the bolt off and put a new one that fixed it, hope my story helps of course i have an slp x now
Old May 31, 2006 | 07:24 PM
rbstang's Avatar
rbstang
if its leaking on the passenger side go to ford buy the passenger side exhaust manifold gasket and replace it.
Old May 31, 2006 | 07:27 PM
d3mon's Avatar
d3mon
ORIGINAL: rbstang
i tried that but you can do that, it will probably fix it
Old May 31, 2006 | 07:30 PM
rbstang's Avatar
rbstang
Edit - NM+
