2k to spend
so i have some grad cash and i want to upgrade my stang. with $2,000 what would be best to do first? and what brand of various bolt-ons
heres what i have seen from reading so far
short throw
cold air or ram air
under drive pulleys
some chip
btw have to get the roush Exhaust because its the only one that will fit my side pipes.. its $889.20 at stage 3 motorsports
short throw
cold air or ram air
under drive pulleys
some chip
ORIGINAL: Zephid
short throw
cold air or ram air
under drive pulleys
some chip
short throw
cold air or ram air
under drive pulleys
some chip
4.10 GEARS (FRPP) + Tuner(SCT XCAL 2 or Predator), TB and Plenum, then bigger/wider wheels and tires. Probably more than $2k, but u can do others later. I just ordered my exhaust stuff, and alot more to come in a couple months.
EDIT: I had posted tonight about an antenna delete type kit, and ur sig says u have it. Can u fill me in on the details please?
+1
Also, I wouldnt waste 200 bucks on a cold air intake, just take the air silencer off, works almost as good as the 200 dollar intakes.
ORIGINAL: dsg04gt
4.10 GEARS (FRPP) + Tuner(SCT XCAL 2 or Predator), Suspension work, TB and Plenum, then bigger/wider wheels and tires. Probably more than $2k, but u can do others later. I just ordered my exhaust stuff, and alot more to come in a couple months.
ORIGINAL: baldwinsgt
+1
+1
ORIGINAL: dsg04gt
a shaker wont do much if anything for you. If you want to go fast right away gears and a tuner. A CAI by itself is next to worthless. Even a CAI+ Throttle body+ plenum will only really give better throttle response rather than noticable power
ORIGINAL: 01SilverGT
$200 for gears
$300 for gear install
$200 for o/r midpipe - install yourself
$400 for slp lm's - install yourself
$400 for DR's
$300 for tuner
$200 for gears
$400 for DR's
$300 for tuner
fit up nicely on my old stock Bullitt rims.......with this Mods list your looking at low 13's as long as you can drive
