steering problem
Old Jun 19, 2006 | 12:22 PM
cottonseed77's Avatar
cottonseed77
Default steering problem
Ok my car has something really wierd going on with the steering. If I hit a spot in the road that is alittle uneven the car wants to pull that way bad. The steering wheel shakes sometimes and shimmies alittle. Also when I hit the breaks to come to a stop the car sometimes but not all times wants to pull alittle to the right. I had the tires ballanced and rotated and an allingment done on the car. But it stills does it. The place I got this done at said they dont fill what im filling but its there. Do you have any idea at what it could be???? Please help me
Old Jun 20, 2006 | 02:56 AM
kconway21's Avatar
kconway21
Default RE: steering problem
I am having the same problem so it's not just you. No clue what it is either.
Old Jun 20, 2006 | 11:11 AM
cottonseed77
bump
Old Jun 20, 2006 | 11:19 AM
amoosenamedhank's Avatar
amoosenamedhank
Are you lowered? Because if you are welcome to the lovely world of bump steer.
Old Jun 20, 2006 | 11:21 AM
cottonseed77
no im not lowerd Unless the person that had the car before me had it lowered. It doesnt look lowered had that 4X4 lool
Old Jun 20, 2006 | 11:24 AM
P Zero's Avatar
P Zero
Replace your tie-rods, both inner and outers. Also check your lower control arm bushings. I had a similar problem with a different car than my stang. The inner tie rods were bad, but I figured I'd replace the outers too, then had it aligned, problems went away.
-P.
Old Jun 20, 2006 | 11:38 AM
cottonseed77
ORIGINAL: P Zero
-P.
Thanks P Zero I will give that a try
Old Jun 20, 2006 | 12:07 PM
Black_sunshine's Avatar
Black_sunshine
my car does the same thing .the shaking was tire balance. but it still wants to pull on uneven pavement. I drove another 03 gt and it did the same thing.
Old Jun 20, 2006 | 12:23 PM
suzukidragracer's Avatar
suzukidragracer
My car does the same thing.
I checked my front lower control arm bushings and they are shot! One of them is even scrunched up in the control arm.
I had my roommate move the steering wheel back and forth from centered about 60 degrees each way, and you can visibly see the control arms move side to side about 1/4" each way!!
So, it follows grooves in the road real bad and sometimes pulls like it's out of alignment.
I'm gonna get some poly ones when I lower it next month....until then, I am just really careful to stay in my lane!
Vince
Old Jun 20, 2006 | 12:35 PM
amoosenamedhank
ORIGINAL: P Zero
-P.
You would hope that the place he took it to get aligned would have told him that. Actually you think they would have told him that either way, those places are always looking for a way to stick ya for extra money.
