a/c issues
Got a 2000 gt that doesnt blow cold air. Thought maybe the system needed to be charged but it is full. While pressure testing, I could hear the compressor turning on and off every second or so! What gives? Any suggestion on why my air isnt cold?
Rex
Rex
Your may be low on freon. System may not be completely full. When the compressor starts, the pressure drops and the compressor is probly kicking off on low pressure. I`ve had this happen on other cars before and that was my solution. Watch the guage when the compressor starts and see how fast the pressure drops.
i actually had the same problem with my 2000 GT when it was a little over 2 years old. I turned on the A/C and couldnt believe that it didnt work in almost a new car. I took it to a dealer and got them to fill it up, the mechanic said the 0-rings didnt seal right and it was slowly leaking out over time . Its been filled for over 3 years now with no problems.
I'm in the same boat at the moment but mine is sporadic cooling. Works or doesn't work, no in between. I've got an 00 with just over 100K so I'm guessing the clutch is going out.
When the pressure drops as the compressor kicks on in your car, does it blow cold air?
The air is never really and has never been cold unless it is already cold outside.
See I live in Seattle, the car is a convertable, so I hardly use the air conditioning (weather is usually pretty cool) but I am moving to a warmer climate and want to get this issue resolved -- nothing like wearing shorts and sitting onto black leather seats that cooked in the sun
Thanks
Rex
Thanks
Rex
Are you sure the compressor is cycling correctly, and not just powering on and powering off??
What about the condition of the rest of the system??
JT
JT
ORIGINAL: GodAmGT00
JT
JT
As far as the rest of the system goes, I get plenty of hot air-- so hot it could melt your leg hairs. The cooling system for the motor is fine as well.
Can you read the high and low pressures in the system? If those are both good, you might want to check the high pressure switch to see if it's acting up. If it's bad, it could be sensing that there's too much/too little pressure and is shutting the compressor off. Same goes for the low pressure.
