over drive broke
when ever i press the over drive button is done nothign the light never comes on, the rpms neva change.. So i think it is broken. How would i fix this and am i driving with over drive on or off since i cant change it...????
your driving with it on if the od off light isnt on. it resets when you turn off your car to od on. do this http://www.mustangworld.com/ourpics/fcar/dtcodes.htm and check if the bulb to that light is out. if it doesnt come on that means the bulb is just out. and you got to replace that. hopefully its just the bulb
I'm thinking that your OD Switch is either bad, or the light bulb is burnt like wwmost stated...
I say the switch first, mainly because if the bulb was burnt out, the RPM's would still increase on a downshift... But it's possible your car just isn't switching into another gear....
JT
JT
ok then im pretty sure its not a bulb..so if its broke that means im driving with over drive off since it wont turn on... so how owuld i fix this if it was broken or should i not wast the money into fixing it..
ORIGINAL: yellowgtstang18
i see so im drving with over drive on... and u dont want over drive on when ur racing do you.??
