Adjusting cluth
Old Jul 16, 2006 | 09:33 AM
Mr_Kebo's Avatar
Mr_Kebo
Default Adjusting cluth
How do youi adjust the clutch? Where are the adjustments made at?
Old Jul 16, 2006 | 11:17 AM
so1o2k3's Avatar
so1o2k3
Default RE: Adjusting cluth
Do you have the aftermarket clutch adjuster? If not, you can't adjust it from the firewall cable.
Old Jul 16, 2006 | 11:41 AM
99gtstang's Avatar
99gtstang
If its factory some you pull the clutch pedal up towards you, if its artermarket.. and you dont have a firewall adjuster...... theres a dust cover on the driver's side of tranny with 1 bolt... take it off.... theres your bolts to adjust....... if new cluth keep an inch of play in the pedal.. otherwise..throwout bearing will be on pressure plate constantly spinning, and wear the grease down then the bearings.....and burn it out.
Old Jul 16, 2006 | 12:35 PM
Mr_Kebo's Avatar
Mr_Kebo
when my car is idling there is a funny squeaking noise, i figured i would try and adjust the clutch cable to see if it fixes it.
Old Jul 16, 2006 | 01:50 PM
99gtstang's Avatar
99gtstang
sounds like throwout bearing........sounds like clutch already to tight.....
Old Jul 16, 2006 | 02:03 PM
Mr_Kebo's Avatar
Mr_Kebo
Assuming it is the Throw out bearing how much would that cost to replace. I was looking at new clutches from spec like the stage 1 and it comes with a new throwout bearing and all that.
Old Jul 16, 2006 | 02:09 PM
99gtstang's Avatar
99gtstang
thats exactly what i thought and what it sounded like...... but when they took it down... bearing was fine... clutch plate had fluid from... rear main leaking and was in pieces.....
Old Jul 16, 2006 | 03:29 PM
99gtstang's Avatar
99gtstang
might as well replace clutch if your going to do a throwout bearing.... i spent.......around 275 for king cobra clutch, bearing, and alignment tool.....and new quadrant and cable.......... around 250-350 for labor.....i think you can gain access to TOB without tranny removal, take of dust cover and see how far you can go.
Old Jul 17, 2006 | 12:34 PM
Blck98GT's Avatar
Blck98GT
I ♥ Acer
Trust me.. did my clutch this weekend.. If youre gonna replace TOB just replace clutch and everything.. Was a pain..
Old Jul 17, 2006 | 12:46 PM
Mr_Kebo's Avatar
Mr_Kebo
I have the 3650 tranny so no king cobra for me i was looking at the Spec stage 1 clutches.
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
