where do i shift?
ok, here's a question for you all. First, how exactly do you powershift? second, what is the best rpm to shift at in each gear to obtain maximum performance? in a 04 mach i mean. thanks everyone
powershifting is the art of never coming off the gas, so you have to know how to work your shift gates........ as far as a mach 1, i really don't know because i have never driven one...
ORIGINAL: CivicStomper96
Im pretty sure power shifting is when shifting a gear, and for that split second your in neutral between gears, you rev your engine.
Tripsevn7 explained it just right.
so basically its something i have to practice? i judt dont want to really mess anything up. its just pretty much shifting as fast as i can without takin my foot off the gas?
YES GET IN YOUR CAR ,PUT IN FIRST .PUT GAS TO FLOOR DUMP CLUTCH.KEEP GAS TO FLOOR AND POP YOUR CLUTCH REAL QUICK IN BETWEEN GEARS,,THATS POWER SHIFTING ,,SHIFTING UNDER FULL THROTTLE,,,,,O HAVE FUN AND DONT MISS ANY GEARS OR YOU WILL BE BUYING A NEW TRANS,,,,ALSO IT WONT KNOCK A SECOND OFF YOUR TIME EITHER,,,SO DONT BOTHER....
