What do heads do?
So lately ive been comtemplating whether or not to buy stage 1 cams. after talking to a friend who got a quote at the local performance shop he said its like $700 for cam install and probably $800-$1000 for cam/head install. So if im gonna do cams more then likely im gonna do heads too. Couple of questions.
What do heads do?
How much rwhp with heads/cams?
What makes them better then stock?
Does $800-$1000 sound reasonable for heads/cams install?
SHOULD i get valve springs (i know its not necessary)?
What do heads do?
I ahev heard ported heads will give you an increase of 40-50hp. With my setup I could probably see 340-370hp at the crank. Yes you need valve springs with any aftermarket cam with .550" lift.
ORIGINAL: 03sonicgt
If your gonna port the heads, you should get some stage 2 cams. Change the springs of course. Thats alot of money man, why not just get some juice??
stage 2 cams without forged block = more or less useless
ORIGINAL: JD1969
Nitrous is 50 state legal, all you have to unhook is line at the bottle and your set.
ORIGINAL: 03sonicgt
Understandable on the juice for your area then. No plans on a built bottom end??
anyone know how much it is to forge a block?
ORIGINAL: so1o2k3
I got quoted $3000 to replace the rotating assemby with forged parts and port the heads.
