sohc & dohc question
Old Aug 3, 2006 | 12:54 AM
black_pearl_gt's Avatar
black_pearl_gt
Default sohc & dohc question
im building a 5.4l engine right now and it was originally a sohc engine but i was wondering besides the heads themselvs what do you have to do to make it a dohc engine has any one done this or is it even possible or worth it thanks in advance for any help
Old Aug 3, 2006 | 11:05 AM
black_pearl_gt
Default RE: sohc & dohc question
nothing?
Old Aug 3, 2006 | 12:48 PM
ASUSMC's Avatar
ASUSMC
Well some Navigators had DOHC heads. Not sure if the heads are really interchangable though. I do know that those heads are expensive out of the *** and you would have to change more than the heads... Wiring harness, timing covers, timing chains. There is a ton more involved than just swapping heads.
Old Aug 4, 2006 | 01:19 AM
black_pearl_gt
well im not to worried about the wiring harness because i dont have one for the sohc i basically have the short block so im just wondering if it is worth it in the power area... why would the heads not be interchangable there are dohc and sohc heads not blocks or is there anyone have anything to add
Old Aug 4, 2006 | 02:37 AM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: black_pearl_gt
I'm not sure on the interchangability... the 5.4 as you know is just a 4.6 with a taller deck height... the longer stroke makes up the extra displacement. Both the 5.4 and the 4.6 are modular designs... so the heads probably will fit... it'll be VERY close if not perfect. As a note, the 2v heads barely flow enough for a 4.6... let alone the 5.4. The 4v heads are going to cost you a bit more though.
Old Aug 4, 2006 | 02:41 AM
phil_gou's Avatar
phil_gou
It is possible on the 4.6 don't know about the 5.4 but you have to cange alot of stuff out to make it work and from what i've read its a pain in the a$$ and cheaper just to buy the DOHC.
http://forums.tccoa.com/showthread.p...highlight=DOHC
Old Aug 5, 2006 | 02:17 AM
black_pearl_gt
well guys im thinking maybe that a good set of PI heads and and some head work and cams might be a better answer for me just one mor e question though does any one know if lightnings are dohc or sohc cause i have a a buddy with the sc set up off his lightning for 300 (hes going to fab up a tt setup) and if so do you think thats a good price
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
