debadging
Old Aug 3, 2006 | 05:04 PM
JimboGT01's Avatar
JimboGT01
Default debadging
Anyone have any pics of a gt with the rear debadged leaving only the GT badge?
what is the easiest way to do it?
Old Aug 3, 2006 | 05:05 PM
rbstang's Avatar
rbstang
Default RE: debadging
the badges have holes behind them.. so you have to fill the holes with like bondo sand it down and repaint it.
Old Aug 3, 2006 | 05:08 PM
StickShifty's Avatar
StickShifty
only the side ones and the ford badge has a hole behind it. the only one you can take off is the "GT" with out replacing it.
Old Aug 3, 2006 | 05:17 PM
racer02GTstang's Avatar
racer02GTstang
ive got all the GT badges off.. but new badges up front.... ive been thinking of getting rid of the ford badge and just putting a different badge over it... im not sure what yet though.
Old Aug 3, 2006 | 05:22 PM
JimboGT01's Avatar
JimboGT01
Any pics? how did you do it? and which ones had holes behind them? left side , right sid, gt on the rear, ford on the rear
Old Aug 3, 2006 | 05:32 PM
StickShifty
ORIGINAL: StickShifty
Old Aug 3, 2006 | 05:34 PM
JimboGT01's Avatar
JimboGT01
short term memory
or
i might be slooowwww[&:]
Old Aug 3, 2006 | 05:45 PM
StickShifty
dont worry about it
Old Aug 3, 2006 | 05:55 PM
Aixtreme89's Avatar
Aixtreme89
I took my GT rear badge off, its just stuck on there with sticky tape. I took a flat head screw driver and a peice of wood, placed the peice of wood on my trunk with a cloth between the wood and my car. Then I took the tip of the screw driver and placed it on the lip of the GT badge, then placed the block of wood in the middle of screw driver and pryed it off. Dont worry the tip of the screw driver doesnt contact the paint because the sticky tape is about 1/8" thick. I did the same thing with the Ford badge. There are two 1/4" holes that hold the Ford badge in but I used some window caulking and filled it and then when it dried used some touch up paint. Even though you can still kinda see where the holes where it looks alot cleaner and better than having the Ford badge on. Then I wanted to take the GT badges off on the fenders of my car. I took one off and there is a hole about a 1/2" big behind it. So I cant fill that, it needs to be welded up. So I left the GT badges on the sides then.
Old Aug 3, 2006 | 06:44 PM
Hoppers04Gt's Avatar
Hoppers04Gt
ORIGINAL: Aixtreme89
That rear end looks hottttt
