rear end
Old Aug 5, 2006 | 04:09 AM
ackuric's Avatar
ackuric
Default rear end
what would cause a clunk in the rear under sharp turns, only under operating temps, not when cold. thanks
Old Aug 5, 2006 | 04:11 AM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: rear end
Could be very bad. Possible broken ring and pinion or differential.
Old Aug 5, 2006 | 04:51 AM
ackuric's Avatar
ackuric
thank god its not my stang, just a friends...
i told him its prolly his diff, and he should plan on an eaton, with 4:10's.
if he did that, think it would remedy his problem?
also when he shifts into each gear, (under light load too, havent noticed it under heavy, would have to ask him) (5 spd) most of the time you get a lil clunk...tranny or u-joints? or maybe tied in w/ the other problem?
and code, what should i do, tuner + gears, or x-pipe then headers first. =O
Old Aug 5, 2006 | 11:14 AM
GodAmGT00's Avatar
GodAmGT00
He may want to check his Tranny mount as well, but check U-joints as "suspect" first. Is there a very pronounced vibration from under you when the car's at highway speeds??
JT
Old Aug 5, 2006 | 11:22 AM
StickShifty's Avatar
StickShifty
ORIGINAL: ackuric
mine does the same thing, i just had my rear end rebuild and it still does the same thing, i am not to worried about it.
Old Aug 5, 2006 | 03:55 PM
ackuric's Avatar
ackuric
no vibration, and the clunk is very subtle, dont even know if i wuold consider it a 'clunk'
its more like a 'thump'
mtgldr
Feb 3, 2024 09:00 PM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
fastbackford351
Sep 12, 2015 09:42 AM
Dragonus18
Sep 9, 2015 01:21 AM
