Steeda Tri- Ax
Steeda Tri- Ax
Got it today and installed it. Set the stops the first time second was to close to would grind when you got on it. Had to go to work so couldnt adjust it. Just got home fixed it. Totally Kick ***. Its a little stiff, but will smooth out. Has alot of driveline noise I dont mind overall. Im very happy with this product! Steeda FTW
RE: Steeda Tri- Ax
Yea the stop bolts take a little while to fine tune but after that you're good. Also, yea theres some added drivetrain noise from the shifter because with the Tri-Ax, as with many other aftermarket peformance shifters, most of the stock factory bushings and noise dampers are removed so you here more from your transmission but thats totally normal. By the way I have a Tri-Ax myself and wouldnt trade it for the world. Good buy!
RE: Steeda Tri- Ax
Only because you've never drove with the MGW!! haha... just kidding...
Glad to see you enjoy the short throw... give it 2 weeks, and you'll never understand how you drove with the stock shifter for so long, haha.
RE: Steeda Tri- Ax
ORIGINAL: St4ng07
start prayin man....[&:]
RE: Steeda Tri- Ax
My Steeda loosened up nicely after a couple of months, my 3650 is alot more ornery cold than my wife's '01 Bullitt, go figure, the '04 tranny has upgraded shift forks and SHOULD be smoother. Mine shifts mint even at redline, I like the Steeda, I got it brand new on E-bay for $90., I'm not complaining.
John
John
