LT problem?
Old Aug 13, 2006 | 06:50 PM
jpaol99's Avatar
jpaol99
Default LT problem?
Had my BBK LT's and O/R X put on about a week ago. Since then if the car sits for 4-5 hours or more when i first take off it bogs for like a minute or so through 1-3. After that its fine. Could this be a tuning problem, running lean etc? could it have something to do with the o2 sensors? Any help would be appreciated. Thanks, Justin
Old Aug 13, 2006 | 07:10 PM
ackuric's Avatar
ackuric
Default RE: LT problem?
when you start the car, and take off for the first time, after its been sitting, do you just take off?
you should let your car warm up a lil before you beat on it, so the oil is at its best viscosity.
Old Aug 13, 2006 | 07:12 PM
jpaol99's Avatar
jpaol99
Have tried letting it warm for like ten minutes to see if that would stop the problem and it still bogs after i take off. This also just started after the header/x install.
Old Aug 13, 2006 | 11:21 PM
jpaol99's Avatar
jpaol99
any ideas on what can be causing this? Thanks, Justin
Old Aug 13, 2006 | 11:29 PM
2000GT4.6's Avatar
2000GT4.6
Thats pretty strange. You arn't having a massive leak or anythign are you?
Are you using a aftermarket tuner? Also, it doesn't do it after you drive awhile, let it idle for a minute, and then go again?
Old Aug 13, 2006 | 11:35 PM
sstang's Avatar
sstang
+1, check for that.
Old Aug 14, 2006 | 01:51 AM
bluepony4.6's Avatar
bluepony4.6
ORIGINAL: sstang
+1, check for that.
I wholeheartedly agree. I had a huge leak and my car ran like crap. I finally went in and changed the gaskets and slapped some stage 8 bolts on it. Ran smooth when I started it up but the Jury's still out on driving it around because I won't be able to drive it until Wednesday.
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
