nitrous users
Old Aug 14, 2006 | 01:07 AM
yellowgtstang18's Avatar
yellowgtstang18
Default nitrous users
any 1 running a 125 dry shot,, i am thinking about running it but i want to know if some 1 else is running it , i can retard the timing with my tuner and have colder plugs and run high octane. I think cold fusion sells lots of jets i mite start out with a 115 shot or something close to that.
Old Aug 14, 2006 | 11:49 AM
bsteen81's Avatar
bsteen81
Default RE: nitrous users
ORIGINAL: yellowgtstang18
I run a dry 125 shot no problem. You on the other hand will not be able to run a dry shot since you have no fuel return line (atleast no ZEX kit) Do you already have it installed? What kit do you have? You just need to remember to retard -2 for every 50 shot. Thats pretty much it. I would stil consider getting a pro tune on a dyno to see max results, and to be on the safe side.
Old Aug 14, 2006 | 02:29 PM
yellowgtstang18
so you dont think i can run a 125 dry shot, what about like a 110 or 115 shot..?
Old Aug 14, 2006 | 03:59 PM
97targa's Avatar
97targa
[quote]ORIGINAL: bsteen81
YES YOU CAN RUN A DRY SHOT ON A 2001 with no return line. THEY MAKE ZEX KITS FOR THAT!!!! 125shot is okay too if you plan on using it very rarely. If your an everyweekend racer I would do a 75 or max of 100 shot. If you don't purge your lines and run lower shot, people will never know you have NOS. It6's a great feeling when they think you have thousands invested into internals and you have a 100 shot kit. My cousin runs 100 shot in his 97 with PI heads with no problems! He has the ZEX kit. He runs low 12's all day long.
Old Aug 14, 2006 | 05:14 PM
damdanger's Avatar
damdanger
i need to jump in here, im gettin nos real soon on a 98gt npi motor, i was plannin on runnin either 100 or 125, is this safe? i have a canned tune on it, have a diablosport, currently i have the spark advanced all the way, what should i do to be on the safe side, im also donna have 4:10s on by then
p.s. the car has 113k miles on it
i just wanna run safe, but as hard as i can
Old Aug 14, 2006 | 05:17 PM
MustangChris04's Avatar
MustangChris04
then retard the timing and get a wet shot.
Old Aug 14, 2006 | 05:20 PM
damdanger's Avatar
damdanger
http://cgi.ebay.com/ebaymotors/N-S-P...mZ300014537227
that is the kit i was gonna buy, will this work well for me? , how far should i retard the timing? and will 125 be ok on this antique motor
Old Aug 14, 2006 | 10:07 PM
damdanger's Avatar
damdanger
also is 4:10 gears fine with nos?
Old Aug 14, 2006 | 10:44 PM
MustangChris04
i wouldnt do anything more than 100. and 100 is even pushing it for such a high milage motor. my motor only has 16k miles and im only going to put a 75 shot.
Old Aug 14, 2006 | 10:53 PM
yellowgtstang18
my kit is already installed and its cold fusion,my motor only has 38000 miles on it so hoepfully it can handle at least a 115 shot..
