Raise the car up in the air. Grab the tire at 9 and 3 and shake it slowly. If there is play, it's your tie rod ends. You would need someone to look if it's your inner or outter, though... If the is play at 12 and 6, then your ball joint has play. Too much of either play, replace the worn items and get an alignment.
sounds about good. I paid more than that from carquest. I'd say get um. You can get by without an alignment for a while, if you measure where the current tie rod is set at, and set the new one to the same position.
You will be very happy with the moog products. I have two moog tie rod ends, and two moog ball joints, and they are the tightest parts of my front suspension right now. [sm=smiley20.gif]
