CUSTOM PREDATOR TUNE/ANYONE TRIED ONE?
Has anyone tried a custom Predator tune or had their car tuned on the dyno and had that tune installed into the predator so you could load it into the ECU/PCM? My mods are not extensive but I feel the stock predator tune is very conservative to avoid any engine damage. I would think a tune produced with the help of a dyno would be the ultimate tune for your car at that time in it's mod additions, anyone tried that? I guess I am looking for HP additions to see if it would be worth the expense. Thanks, mark
Mod list would look like this:
1. 4.10's
2. Predator tune
3. PYPES catted X-pipe/catback
4. Steeda UDP's
5. JLT CAI
6. 75mm BBK TB/C&L plenum
Possible fuel mods like fuel pump upgrade or changing to 24# inj's. Thanks, mark
1. 4.10's
2. Predator tune
4. Steeda UDP's
5. JLT CAI
i used the preadator tune. i advanced the timing to max, which i think is only about a degree. you can change for your gears and all that other good stuff (fan temp, etc.), but i would be careful if you're thinking about playing with the a/f ratio with out dyno. ive heard of some people gaining decent numbers using a dyno with the predator, i haven't been dynoed and haven't noticed too much of a change since i've installed my tune.
edit: i saw you have an auto, ive heard people say that playing around with the shift firmness, etc. can offer a noticeable difference, but you'd have to ask around.
ORIGINAL: busterdon't have a predator, hypertech............picked up 2 tenths
To guys with the Predator who have a custom tune did you give them a list of your mods and then they had a nearby vendor burn a new tune just for the mods you submited? Do they tell you what they are changing and by how much? I would like to get a custom tune but would also like more feedback! Thanks, Mark
ORIGINAL: sweet99
.2 quicker than the canned tune that came with the hypertech? That's good. Do you know what was changed from the stock hypertech tune to the custom tune? I know/believe with Diablo that they send the tuner to one of their vendors who makes the actual changes. I like to know what is being done.
ORIGINAL: WAG03GT
+1
ORIGINAL: sweet99
I just recently bought the Predator, and I uploaded the Diablo Tune it came with into my car and noticed a bit of a difference. I'm going to advance the timing further, since I'm running 93 octane, and see what happens. As far as custom tunes, you can get a PC connection cable and a AC adaptor power soucrce that will allow you to plug the tuner into your PC and then you can give the list of mods to a vendor, who will then set up a custom tune and then email it to you. Using a program you can download from Diablosport's website you can then download that custom tune into the Predator, then upload it into your car. While this is good, a dyno tune will always be the best, but more expensive, I'm pretty sure.
I had my car tuned on the dyno with the predator at a very reputabile shop and gained 24 hp and 30 ftlbs. i had all the mods in my sig except for the short throw, flywheel and clutch in.
ORIGINAL: buster
Sorry, I don't know, but I do know that with the performance tune in the car absolutely drinks gas.
