Help! tranny problems AGAIN!
Old Aug 21, 2006 | 01:07 PM
Auto03's Avatar
Auto03
Default Help! tranny problems AGAIN!
i have an 04 gt with 22k miles on it and i've already had 3rd gear synchro's go out on me and then 3rd gear totally went out.......i had ford rebuild the tranny under warranty and then 2 weeks later i'm down shifting from 5th to 4th and it felt like it only went about half way into gear but when i let go of the clutch it was still in 5th gear.......i tried to get the shifter to move outta 4th but no luck wouldn't budge......the shifter is in the neutral postion but the tranny is still in 5th gear.......what could have happened.......the tranny felt really tight after i got it out of the shop and some times if i was gettin on it in first gear it wouldn't go into second or it was really hard to get into gear........i'm takin it back to ford, but is this something i did or is this something they messed up on when they rebuilt it......
Old Aug 21, 2006 | 01:11 PM
oxfordgt's Avatar
oxfordgt
Default RE: Help! tranny problems AGAIN!
Do you have an aftermarket shifter? Check the fluid level in there maybe ford forgot to put it in. If you still have a warranty take it back.
Old Aug 21, 2006 | 01:14 PM
monkeydude3's Avatar
monkeydude3
well.... a shift fork probably broke, or wasn't put in right.
Take it back to the ford geniuses
Old Aug 22, 2006 | 07:03 AM
FDNYBullitt's Avatar
FDNYBullitt
It does sound like a broken fork, bring it back to Ford and tell the idiots to perform TSB 04-15-6 on the trans which is another rebuild but with better parts and stronger forks. From what I read your still under warranty so its a freebee, good luck.
Old Aug 31, 2006 | 12:46 PM
Auto03's Avatar
Auto03
lets say it's a broken fork, how the hell could i of broke it when i was just driving it like a normal sain person.....lol.......could they of tightened stuff to tight or got things all outta wak?
Old Aug 31, 2006 | 12:49 PM
red2k1gt's Avatar
red2k1gt
Either way its not your fault...just take it back and complain a lot and try and get free stuff out of them.
67LimeCoupe
Sep 30, 2015 04:46 PM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
