its rough!
in drive, my car has a shake, and an inconsitent knocking sound, in reverse, its very smooth.
would you guess my exhaust is hitting something, or....a worn/broken motor mount...or tranny mount. :/
I'll disagree with both of the above suggestions. A dead cly or a bad coil would always cause the problem not just in drive.
Does it only do it at a certian speed? If so could be your harmonic balancer or your flywheel, which would be the reason it only does it in drive.
well i just messed around w/ my exhaust. when shaking from side to side i heard a knock up front.. couldnt find what exactly was making contact...so i looseneed up the driver side, jacked up the muffler a lil, and re-tightened. seems to have gone away? time will tell...if so, code was right! he mentioned it could be my exhaust, in chat last night.
off topic, sorda. i have the mac adjustable tips, and the bolt and nut that go into a sliding bracket, for teh tip, are free spinning, i cant loosen or tighten it. so it allows the driver side exhaust to wobble more. any tips to get that bolt off? i just sprayed it w/ pb plaster hoping it will help.
k fixed the tip problem....had 3 threads to grab with some pliers, as i tightened the bolt.
back to the orginal topic. problem still persists, gonna mess w/ the exhaust some more...
heard the knock as she cranked over.
