track help..first time
Old Aug 27, 2006 | 02:27 AM
gsxrstang69's Avatar
gsxrstang69
Default track help..first time
So this friday im taking my car to the track for the first time. Its a 97 cobra with flows, lowering kit, intake. Im running on Falkon tires sittin on 19"s. I know they slow me down and that I shouldnt expect to hook up too well. What are some tips so that I can get the best time possible.
Old Aug 27, 2006 | 02:42 AM
ShadowDrake's Avatar
ShadowDrake
Default RE: track help..first time
Spin the tires a little bit to get whatever sand and junk may be on there... don't need to make any smoke, just a little spin. Avoid the water in the burnout box. When launching, don't just dump the clutch... play with throttle/clutch combos till you hit the point where your tires are about to lose traction, but haven't yet... and you end up with the clutch out at higher than 3000 RPM... after that, have fun
Old Aug 27, 2006 | 04:06 AM
MustangMan528's Avatar
MustangMan528
drive as fast as you can...... always works for me.
Ooooh, and try not to crash.
Old Aug 27, 2006 | 11:10 PM
gsxrstang69
what rpm's do you guys launch at? I was thinking if launching at like 2200
Old Aug 27, 2006 | 11:35 PM
JJ03MustangGT's Avatar
JJ03MustangGT
for me sometimes i go to a different track every now and then, so ill make a few different runs at different rpms. dont just dump ur clutch either, feather it. i like to start at like 3000 and work my way up. depending on the track, go with what works best. if u start to spin ease of the throttle just enough to where itll hook, then get back in it. ur gonna need to practice with the lights too, its gonna take a while, but ull get, just practice. good luck. post ur times when u get em.
Old Aug 27, 2006 | 11:41 PM
97 5.0L's Avatar
97 5.0L
ORIGINAL: JJ03MustangGT
for me sometimes i go to a different track every now and then, so ill make a few different runs at different rpms. DONT JUST DUMP UR CLUTCH EITHER, FEATHER IT. i like to start at like 3000 and work my way up. depending on the track, go with what works best. if u start to spin ease of the throttle just enough to where itll hook, then get back in it. ur gonna need to practice with the lights too, its gonna take a while, but ull get, just practice. good luck. post ur times when u get em.
+1 Dont dump it. lots of first timers dump the clutch at the track.
carid
Jul 8, 2016 09:55 AM
StalkerGT
Sep 25, 2015 02:41 PM
RWHEELS
Sep 5, 2015 03:42 PM
whatsup62
Sep 3, 2015 01:38 PM
Sep 1, 2015 08:16 PM
