Midpipe Install
Old Aug 31, 2006 | 04:06 AM
Adam03GT's Avatar
Adam03GT
Default Midpipe Install
I just got my Mac offroad X-pipe in. Before i got under my car i was wondering how hard it is going to be to install the MILs and the extended 02 cencors(which u have to do on 03s). Im assuming its all easy bolt-on? Anything i need to look out for? thanks
Old Aug 31, 2006 | 08:41 AM
Ostang04's Avatar
Ostang04
Default RE: Midpipe Install
installing the mils and O2 is easy just unplug, then plug all togher. loosening the nuts on the passanger side holding the midpipe to the manifold is the hard part. I would suggest soaking them possibly overnight in wd 40, liquid wrench or some penetrating grease like that.
Old Aug 31, 2006 | 10:28 AM
monkeydude3's Avatar
monkeydude3
if WD40 don't work you may have to use heat. The passenger manifold to midpipe connections are usually the biggest PITA and you have to take the 02 out first.
Old Aug 31, 2006 | 12:04 PM
Cornbread01's Avatar
Cornbread01
should not be hard all of 8 bolts i used this stuff called mouse milk very good penitrating lub takes 15mins for it to work
Old Aug 31, 2006 | 12:37 PM
red2k1gt's Avatar
red2k1gt
Make sure you soak the bolts in something to loosen them up or your going to trying to take that thing off forever.
Old Aug 31, 2006 | 01:47 PM
03sonicgt's Avatar
03sonicgt
ORIGINAL: red2k1gt
+1
Old Aug 31, 2006 | 02:01 PM
Mark11's Avatar
Mark11
Pb blaster works miracles, I had some trouble with the bolts when I did my exhaust, but that stuff loosened them up so much I could have undid them with my fingers.
Old Aug 31, 2006 | 02:08 PM
d3mon's Avatar
d3mon
ORIGINAL: Mark11
+1 i've used that stuff it works great, for my exhaust however i used and impact wrench,,, worked like a charm
Old Aug 31, 2006 | 03:22 PM
SNORX302's Avatar
SNORX302
+1 on the pb blaster-soaked the bolts on the manifold collectors for like half an hour-came off like butter-ur gonna need a swivel joint and a lot of extensions-probably about 12-15 inches worth
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
