Help me Please >>>
I have M GT 1999
Transmission: 5 speed Manual
The problem is when I shifting form 4 to 5 while I drive slowly about 80 - 90 Km/h
The gear made nose sound and made vibrations
What the problem with it and how can I solve this problem?
pleaaaaaaaaaaaaaas>>>>>>>> >>>>>>>>>>>
So around 50 MPH? No Kph here!
No trouble in the other gears, reverse? I am not a manual guru but I would say the tranny is bad. I have read that there is a model of tranny/5-speed that is problematic. Guys with sticks, help here? mark
I have push the clutch far enough in >>>
also ther are No trouble in the other gears, reverse but some time reverse dose's go in ,So I try again to reverse >>>>
and what the meaning of tranny , how can I solve this problem??
If there any parts should I change
Do you please show me some pic of this parts
tranny=transmision
when going into reverse it is better to put it in 5th first wile the clutch is still in then shift to reverse... as far as it not going into 5th check your clutch cable and try to adjust it.....lift the clutch all the way up towards the roof then press it all the way down and then it is adjusted. if that dont work start with the cheap stuf like clutch cable...they tend to stretch and shred apart. hope this helps
