4.6 comparison
Old Sep 6, 2006 | 03:23 PM
elmustang5.0's Avatar
elmustang5.0
Default 4.6 comparison
whats the difference between the 96-98 4.6 motors and the 99-04 motors. what causes such a power increase?
Old Sep 6, 2006 | 03:27 PM
hotrod7687's Avatar
hotrod7687
Default RE: 4.6 comparison
96-98 has about 215 hp, 99-04 has about 260 hp. The difference comes with improved heads, more aggressive cam and tune on the 99-04 models.
Old Sep 6, 2006 | 03:28 PM
Chad99gt's Avatar
Chad99gt
The heads and intake were changed in 99 to the PI style (performance improved) I believe the cams might have been changed also but im not sure...
Old Sep 6, 2006 | 03:29 PM
elmustang5.0
so how much will it take to get an early 4.6 to perform like the 99-04?
Old Sep 6, 2006 | 03:31 PM
Chad99gt's Avatar
Chad99gt
pi swap... theres a ton of information on it, just google pi swap and u should get alot of useful information
Old Sep 6, 2006 | 03:32 PM
hotrod7687's Avatar
hotrod7687
You can do a head swap to the 99-04 PI heads. You also have to change intake when doing this. Its a fairly common swap, there should be lots of info here on how to do it. With that swap, and a tune you should be making just a little more power than the 99-04's.
Old Sep 6, 2006 | 03:33 PM
elmustang5.0
cause i was looking at this car and it says it has a pi conversion. what do you guys think is this a reasonable price?http://www.autotrader.com/fyc/vdp.js...000&cardist=12
Old Sep 6, 2006 | 03:46 PM
hotrod7687's Avatar
hotrod7687
I couldnt get that to work
Old Sep 6, 2006 | 04:36 PM
ShadowDrake's Avatar
ShadowDrake
Here's a WORKING LINK that doesn't make the thread go gay. For long links please use the link feature of the site... isn't that a rule or something?
It says it has the PI swap done, so you can expect it to have a bit more power than a 99-04 GT (the 96-98 GT's don't have dished pistons, 99-04 do, so you'll have a slightly higher compression ratio... only about a half a point. You should still use premium fuel though).
May 9, 2024 05:51 AM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Sep 23, 2015 01:28 PM
rksnow1
Sep 14, 2015 08:46 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
