T-45 problems...please help!
Old Sep 24, 2006 | 04:58 AM
so1o2k3's Avatar
so1o2k3
Default T-45 problems...please help!
I just bought a King Cobra Clutch kit, and it's sitting on the floor waiting for install. I know for sure the clutch needs to be replaced, but the other problem is I have a feeling my tranny is shot. Whenever I drive WOT, the 1st to 2nd shift always grinds horribly and it also does the same in 4th gear sometimes but not as much. It's not me being a bad driver, because I've driven it hard before without any shifting problems, but recently 2nd and 4th gear seem to be grinding a whole lot. Anyways, I'm wondering if I should just install the king cobra clutch assembly with some royal purple synchromax fluid and hope for the best, or would it be a waste of a clutch if I needed to replace the tranny anyways?
Old Sep 24, 2006 | 03:57 PM
Rantheman's Avatar
Rantheman
Default RE: T-45 problems...please help!
that could all be happening because your clutch need to be replaced but if you do need a new trans and are short of cash go here http://www.tbtrans.com/manual_transmission.htm and scroll down to ford racers you will see
Rantheman's Avatar
Rantheman
wait do you have a t-45 or a t3650
Old Sep 24, 2006 | 05:40 PM
so1o2k3's Avatar
so1o2k3
T-45
Old Sep 24, 2006 | 05:42 PM
Matts00GT's Avatar
Matts00GT
Synchros...
Old Sep 24, 2006 | 06:15 PM
Rantheman's Avatar
Rantheman
well you can spend a few hundered bucks to have your tansmission torn apart to be checked or you can replace your clutch to see if the problem cures or buy a rebuilt or new trans or get more opinions!!
Old Sep 24, 2006 | 06:27 PM
whty98's Avatar
whty98
If your clutch def needs replacing, then it may be slipping and that would cause grinding while trying to shift. Replace the clutch and fluid and see what happens. I did the same exact swap on my 98GT but that was due to the TO bearing going to ****, everything worked smooth when done.
Old Sep 25, 2006 | 02:28 AM
so1o2k3's Avatar
so1o2k3
Thanks for the replies guys. I'm just hoping it's the throw out bearing or something like that. I'll post an update after I get it replaced.
Greyshot
Aug 15, 2015 03:32 AM
01BlueCobraVert
Feb 1, 2006 12:28 AM
thirteensecondgt
Dec 24, 2005 04:23 AM
Nichepi
Jul 13, 2005 08:48 PM
PhantomGT
Mar 17, 2005 02:34 PM
