Diablosport
Back to the original post...I'm sorry you bought the chip.
They are pure garbage. Not worth $25 bucks even. Canned tunes are garbage, performance chips are just more expensive ways to waste your money.
Please get a dyno tune if you are looking for any HP improvements.
ORIGINAL: Dan04COBRA
Well, that sucks. It wasn't the tune in a can though, the owner of the shop was customizing one that would best benefit my car. I just took it to them about an hour ago, they are going to see what they can do for me.
As for the reason I got it though, I know you need to recalibrate the speedo when you get gears, so that's just one thing that I won't have to worry about later.
So i'm guessing that buying it was pointless and I should have spent the money on other things?
Correct me if I'm wrong, but I believe the speedo can only be corrected with one of those little tiny gears rather than a tuner in cars 98 & older.
ORIGINAL: micheal0484
Hey my diablo wont let me ajust the axle ratio anyone know whats up with it?
and tuners arent garbage, first... it allows you to advance timing....steeda timing adjuster can also do that for 150 bucks
you can change your gear ratios when you swap....but a speedcal can do that.... for about75 to 100 bucks
and you can turn off your O2 sensors... but MIL eliminators can do that too... for 75 bucks.... and they usually go bad
savings from a tuner= about 325 bucks, which is more than i paid for my predator
ORIGINAL: TruckStang
ORIGINAL: tcuallstar
ummm, no its 98 and older that you have to use a programmer or speedcal
Hey if you have to have a tuner to adjust the axle ratio, do you know why mine wont come up?
t3000
May 10, 2005 09:03 PM
