Emission problem
Old Sep 29, 2006 | 12:35 PM
kamelyn's Avatar
kamelyn
Default Emission problem
My check engine light has been on for a little while. I took my car to Autozone to pull the codes off of the OBD2 and it comes up with p1401 and p1441. I have changed out the EGR Valve, and the EGR pressure sensor, but i still have the same problem. I haven't noticed any change in performance over the time that it's been on. I need to find out what i can do to fix the problem because emission time is coming up in the next month, plus i hate seeing the check engine light. Any input would help.
Old Sep 29, 2006 | 11:52 PM
kamelyn's Avatar
kamelyn
Default RE: Emission problem
bump
Old Sep 30, 2006 | 12:24 AM
jst854's Avatar
jst854
I had that happen a while ago, i dont remeber the code though but it looked similiar to yours. It was a valve and sensor(cant't remember the names, i will try to look it up though) It was like $90 or something from Ford for both of them and took about 5 min to install.
Old Sep 30, 2006 | 12:27 AM
jst854's Avatar
jst854
nvm my code was P1433 and it was the evap valve and sensor, good luck though
Old Oct 7, 2006 | 11:34 AM
kamelyn's Avatar
kamelyn
bump
Old Oct 17, 2006 | 02:36 AM
kamelyn's Avatar
kamelyn
bump
Old Oct 17, 2006 | 02:47 AM
97targa's Avatar
97targa
Look under your hood and make sure all connectors are plugged in. I unplugged an emissions part when I pulled off my plenum and had the same problem. It was next to the EGR valve and is black and looks like the top of it can be unscrewed like a cap! That's the best way I can describe it. Check that, because I got the same code!
Old Oct 17, 2006 | 02:49 AM
uberstang1's Avatar
uberstang1
Chupacabra
ehhhh who needs emissions, tune it out and tell ford to stick their save the planet pumps right up their ****.......mine just threw the code for the evac too, but i can careless about emissions at this point i have no cats or smog pump
Old Nov 14, 2006 | 11:28 PM
kamelyn's Avatar
kamelyn
Unfortunatly I have to pass emissions since it's a requirement in my county in Georgia in order for us to get our annual renewal tags.
Old Nov 14, 2006 | 11:44 PM
trance565's Avatar
trance565
ORIGINAL: kamelyn
did you reset the computer? also, if you cant figure it out, just unplug the battery for 5 mins, right before you get it inspected, cuz you gotta drive it like 15-30 miles in order for it to come back on.
also, did you get it checked after you replaced the parts? it might be throwing a different code now.
Seanam
Oct 4, 2015 10:15 AM
mltdwn12
Sep 23, 2015 08:54 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
rksnow1
Sep 14, 2015 08:46 PM
