Subframes?
Old Sep 29, 2006 | 04:59 PM
stanger88's Avatar
stanger88
I ♥ Acer
Default Subframes?
How "flexy" are the 02-04 GT's I heard a long time ago about subframes coming standard starting in 99' from the factory??? How do these cars compare to F-bodies for rigidity? Any empirical data (degree deflection under XXXXX # torsion, ect would be AWESOME!)
Old Sep 29, 2006 | 05:21 PM
Chopper's Avatar
Chopper
Default RE: Subframes?
I just put full length subs on my 04 and it makes less "squeaky,clunky" noises when I drive it.It never was bad but it's quieter now.I did quite a bit of research before I bought mine and decided that it was a worthwhile mod to start toward improving the handling of the car.I also was looking to the lifetime of the car and I didn't want it to start making noises as it gets older.(I promised Mrs.Chopper that I would NEVER ask for a new car again)
I say full length subframe connectors are a good modification.Mine were from Steeda.I was torn between Steeda and Maximum Motorsports but went with the Steeda parts because they require less welding.
Old Sep 29, 2006 | 07:36 PM
sandcracker21's Avatar
sandcracker21
ORIGINAL: Chopper
i dont mean to jack the thread, but where did you take yours to? or did you weld them yourself??
how much was the install on them
how much of a difference?
Old Sep 29, 2006 | 07:40 PM
stanger88's Avatar
stanger88
I ♥ Acer
^not a hi-jack, I want to know too.
Old Sep 29, 2006 | 07:48 PM
ben790450's Avatar
ben790450
I ♥ Acer
Sub frames come standard on verts only. Full length weld ins make a big difference IMO. I had my mechanic weld mine in. its a pretty simple job but he was under there doing my exhaust so i had him slap um up.
Old Sep 30, 2006 | 12:13 AM
HYBRED's Avatar
HYBRED
Subframes, as far as I know, were only standard on 03-04 Mach 1's. The Convertibles do have extra structural support, but not technically subframes. It's one of those mods that every Mustang that is raced should have. I know that my 109k mile doors shut better than a 22k mile Cobra because the Cobra was raced without subframes for so long, while mine was babied (until I got ahold of it, that is) Mustangs launch well; that puts a lot of strain on the unibody. It's definately a mod to do; it reduces chassis flex, and as a bonus it does make the car more responsive because it's actually turning instead of flexing.
Old Sep 30, 2006 | 01:58 AM
stanger88's Avatar
stanger88
I ♥ Acer
awesome input so far, THANKS!
Old Sep 30, 2006 | 02:32 AM
IWinULose's Avatar
IWinULose
Does the carpet need to be removed before the full lengths are welded in?
Old Sep 30, 2006 | 02:36 AM
stanger88's Avatar
stanger88
I ♥ Acer
ORIGINAL: IWinULose
My tech removed mine when he put in mine on the 5.0,but we did a LOT of stuff to the car and the carpet was out anyways. I think he said it did, but again, thats on a fox.
Old Sep 30, 2006 | 03:29 AM
wildazme's Avatar
wildazme
hold on subframes go inside the car? why would you need to remove the carpet? i thought they welded onto the bottom of the car?
