High compression or low
Old Oct 8, 2006 | 06:15 PM
ben790450's Avatar
ben790450
I ♥ Acer
Default High compression or low
Well with winter coming (its snowing outside right now) and me started to work full time as a FF here in a few months im going to put the old girl to sleep and start to spend some cash. My engine is dying and i am too scared to race on it anymore as it has upwards of 125k + on it so its time for me to start thinking about engine upgrades. I want a stroker. Im a stroker guy and no one is going to talk me out of it. I need a new short block with forged internals so might as well go with the 5.1 stroker. Im going to rip the stangs heart apart, send the heads in to be P&P, get new cams and intake, and then do all the suspension and interior work (tubular k-member, full coil overs, adjustable steeda sway bars, 18" rims, corbeu race seats, 6 point roll cage) Looks like ive finally chosen my tranny. B&M Ford AOD. Its a three speed w/ OD so itll be perfect with my 4.10's or i might even be able to get away with 4.56's. But anyways i want to put a 200 shot direct port on the 5.1 so ill around 500 at the wheels maybe a little more or less but heres the poll: Should i go with a major high compression in the stroker kit so ill have massive power up front or go with a mid to mild compression so i can throw on a vortech later but have no power up front. High compression= 560 or more rwhp (with no future of FI) Low compression= 490ish rwhp (with possibility of FI in the future). With FI in the future ill beable to push around 600ish rwhp but i may never do FI. Idk
Old Oct 8, 2006 | 06:18 PM
Matts00GT's Avatar
Matts00GT
Default RE: High compression or low
If you're just going to run nitrous, you can go higher on the compression. If you plan on upgrading to a blower later, keep the compression low.
Personally, I'd go about 8.5/1. You can still run nitrous just fine on that compression and then later you can put on a supercharger/turbocharger and not have to worry about boost issues.
Old Oct 8, 2006 | 06:21 PM
ben790450's Avatar
ben790450
I ♥ Acer
Ya thats what im leaning more towards too. Like we all do, im going to get bored of the 500 is rwhp and want to F/I when all my cobra buddies are doing 600 rwhp and still walking me [&:] and im gonna get pissed and go get a good centri with meth injection and push another 120 horses or so out of it.
Old Oct 8, 2006 | 06:22 PM
Matts00GT's Avatar
Matts00GT
You can still run nitrous with the blower. I'd put the F/I on and then like a 75 shot that sprays from like 1500 rpms-4k rpms to get it into boost quicker.
Old Oct 8, 2006 | 06:23 PM
ben790450's Avatar
ben790450
I ♥ Acer
Like go with a blower from the start? Well with fully forged i can run a 100 shot just fine. Or get a two stage kit. But either way with a nw manifold a direct port kit is the best bet IMO
Old Oct 8, 2006 | 06:26 PM
Matts00GT's Avatar
Matts00GT
Eh, it doesnt really matter what you go with first. Its really more like "what do you want?" With a built motor, why not go with the blower first? You can set the boost at pretty much any level and not have to worry about destroying a piston or rod. Hell you could run safely at 20 psi. I dont recommend it, but you could.
Also if you do the motor/supercharger combo, you will see more than 500 rwhp.
Old Oct 8, 2006 | 06:29 PM
Colorado_Mustang's Avatar
Colorado_Mustang
If you can build the blower motor over winter, go that route.
Otherwise, go for a high compression screamer.
Old Oct 8, 2006 | 06:33 PM
ben790450's Avatar
ben790450
I ♥ Acer
eh yeah. Dont know if i can afford to do like a KB 2.2 with as much as the rest of the buildup is going cost i probably only be able to get a Vortech or the like plus i want to keep my Ported 75 mm TB & UI i already paid for haha but i can push 14 or 16 psi out of that blower safely.
Old Oct 8, 2006 | 06:45 PM
ben790450's Avatar
ben790450
I ♥ Acer
Then again . . . a KB 2.1 bigbore utalizes the stock TB and with a 14psi pulley makes 262 rwhp and 229 rwtrq. That'd be around 600 rwhp or so, with a meth kit and some 60 lbs injectors. A 100 shot may be pushing it. Idk. Do they have pulleys to make a vortech or the like go to 14+ psi?
Old Oct 8, 2006 | 06:49 PM
Matts00GT's Avatar
Matts00GT
ORIGINAL: ben790450
Lol yes.
