clutch question
Old Oct 10, 2006 | 02:57 AM
so1o2k3's Avatar
so1o2k3
Default RE: clutch question
It is not worth the cost of labor to just replace the throw-out bearing. You might as well replace the enitire clutch kit. If you think your linkage is a problem, you can just buy a Steeda Firewall adjuster and have it installed with the clutch. Even if the linkage isn't the problem, it's still good to have so you can adjust the cable if your clutch happens to get loose. If you are consistently missing shifts, it could also be the synchronizers. When you replace the clutch, some Royal Purple Synchromax Tranny fluid wouldn't hurt either. Repairing/replacing synchros can cost big bucks...so hope its not the problem.
Old Oct 10, 2006 | 04:07 AM
03sonicgt's Avatar
03sonicgt
Dustin, get a spec stage 2 if you want to run nitrous next year. Thats what I'll get once my stock clutch goes, gotta love the stock clutch with 400hp.
Old Oct 10, 2006 | 11:46 AM
djb1187's Avatar
djb1187
true, might as well get the stage 2 since I plan on having big power...i wish these cars werent so expensive...[&o]
Old Oct 10, 2006 | 12:04 PM
travisl1213's Avatar
travisl1213
the stage one holds 410 lbs of torque
Old Oct 10, 2006 | 12:06 PM
djb1187's Avatar
djb1187
thats a hell of a stage 1 clutch. Maybe my problem is related to my shifter, i have a steeda tri-ax off of a t-45...
Old Oct 10, 2006 | 12:22 PM
so1o2k3's Avatar
so1o2k3
My tri-ax worked fine until my synchros started going...hate to say it but it's probably the synchros.
Old Oct 10, 2006 | 12:28 PM
travisl1213
yea specs products are nasty
Old Oct 10, 2006 | 12:36 PM
RedAlertlb's Avatar
RedAlertlb
how did you bolt a t45 shifter to a t3650?
Old Oct 10, 2006 | 12:43 PM
djb1187's Avatar
djb1187
ORIGINAL: RedAlertlb
Man I dont know how the hell we bolted it but we did. It came off of a 96 cobra and it bolted on there fine. Another problem i noticed is my car is kind hard to get in reverse, it usually grinds and most of the time i got to double clutch to make sure its firmly in. I wonder if shifter is the problem since I do have a 3650 and I just found out steeda makes a diffrent shifter for the 3650
Old Oct 10, 2006 | 12:50 PM
travisl1213
yea its prob ur shifter......
