How does your Mustang start?
Old Oct 11, 2006 | 11:02 PM
stang2000's Avatar
stang2000
Default RE: How does your Mustang start?
Fuel filter is really easy. The filter is right in front of the gas tank facing the front of the car. Depressurize the system and use a ford fuel/ac line remover from your local auto store. Set of 6 sizes about $10.00. I unplug the harness from the fuel shut off(in trunk, left side, behind trim panel in corner), then either start the car and let it die, and also pree the pressure relief valve on the front right corner of the passenger fuel rail.
Plugs are also fairly simple in my opinion. I pull the fuel rails off(might as well since you'll be removing the fuel pressure anyway), take the boots off the plugs(coil on pack) and then remove the plugs.
Old Oct 11, 2006 | 11:15 PM
CobraStangGT16's Avatar
CobraStangGT16
Mine starts up fine. Sometimes when I havn't started her up in a few days, it takes a bit of time. My cousin was starting the car one day and I guess he didn't hold it long enough? But it looked like the engine was striving for a second. Like it was trying to catch up. I don't know if it was his fault for not holding it, or something else.
Old Oct 11, 2006 | 11:32 PM
7earitup's Avatar
7earitup
ORIGINAL: stang2000
Really easy huh? Sounds kinda complicated.. haha
Old Oct 11, 2006 | 11:38 PM
7earitup's Avatar
7earitup
What brand of spark plugs do you guys use? I have heard good things about the Denso Iridiums'. Any brand names that you prefer for the fuel filter?
Old Oct 11, 2006 | 11:44 PM
Monch's Avatar
Monch
the way these engines work, the computer has to determine where cylinder #1 is (or some reference point) and only after doing so does it allow a start. or something like that, but in can take a range of time to make the dertmination as the crank ain't spinning very fast.
Old Oct 11, 2006 | 11:48 PM
Brute03's Avatar
Brute03
autolite 764's are pretty good, changing plugs is as easy as removing the coil and then the plug, it's easy man
Old Oct 11, 2006 | 11:50 PM
7earitup's Avatar
7earitup
Is it a good chance that the new spark plugs and fuel filter will fix the starting issue?
Old Oct 11, 2006 | 11:54 PM
sprostang's Avatar
sprostang
I ♥ Acer
I would get NGK TR55 plugs. They seem to be the best for a N/A car.
Old Oct 12, 2006 | 12:05 AM
StickShifty's Avatar
StickShifty
ORIGINAL: stang2000
just waisting your time doing that.
use NGK TR55's. very good plugs
Old Oct 12, 2006 | 12:50 AM
kcp1989's Avatar
kcp1989
+1 they THE plug for the gt
