RTV vs Shifter Gasket
Old Oct 15, 2006 | 11:37 PM
MCanavan6's Avatar
MCanavan6
Default RTV vs Shifter Gasket
Ordering a MGW Short Throw Shifter soon and am trying to decide if I should get a shifter gasket as well or just use RTV to install it. Any advantages or disadvantages between the two? I am leaning towards the shifter gasket unless there is a disadvantage to it.
Old Oct 16, 2006 | 12:20 AM
MCanavan6's Avatar
MCanavan6
Default RE: RTV vs Shifter Gasket
anyone?
Old Oct 16, 2006 | 12:36 AM
gt96stang's Avatar
gt96stang
Eh, the shifter gasket is cheap and I've got one.. I just got one because I changed tranny fluid and decided I didn't want to use the RTV... Before I got the gasket, the RTV worked just fine.
Old Oct 16, 2006 | 12:37 AM
BraMas's Avatar
BraMas
no disadvantage to the shifter gasket. You can also go to the autoparts store and get the gasket material where you trace the shifter and make your own gasket.
Old Oct 16, 2006 | 12:48 AM
MCanavan6's Avatar
MCanavan6
ORIGINAL: BraMas
So basically it is just a replacement for the RTV?
Old Oct 16, 2006 | 12:59 AM
gt96stang's Avatar
gt96stang
ORIGINAL: MCanavan6
Yes. and smart idea ordering the best shifter out there..
Old Oct 16, 2006 | 01:04 AM
II 98 GT II's Avatar
II 98 GT II
Cobrabob's shifter gaskets man.. they work great. The guy's a sponsor to the forums too... Just make sure you don't crank the shifter down too tightly and distort the gasket (if you decide to go that route).
Anyways, my vote goes to cobra bob.
Old Oct 16, 2006 | 09:49 AM
BraMas's Avatar
BraMas
But without the mess.
ORIGINAL: MCanavan6
ORIGINAL: BraMas
Old Oct 16, 2006 | 10:42 AM
DTK's Avatar
DTK
Definitely go with the gasket.
Do you want to do this twice?
You can go with RTV and as long as it is done right......no worries.
However, when you put in a gasket, you are 99% home free unless you bolt it down incorrectly.
No mess, no worries with the gasket.
Old Oct 16, 2006 | 12:49 PM
wes ley n the G T's Avatar
wes ley n the G T
ORIGINAL: II 98 GT II
I wouldnt reccommend a gasket because when I screwed the base of my shifter down tight, over time it worked the gasket out of place and I had tranny fluid flying around everywhere under my shift boot and had to do the whole process over again. Get some gasket maker or high temp RTV and be done with it.
