engine rpms increase
Old Oct 20, 2006 | 10:37 AM
jbodak's Avatar
jbodak
Default engine rpms increase
I very recently had a 70mm throttlebody and plenum installed plus had it custom tuned with an SCT Excalibrator2. One thing that happens on an intermittant basis after the engine has warmed up is when I push in the clutch and my foot is off the gas pedal, the engine revs up to about 1800 - 1900 rpms. It drops right back down when I put it in gear or if I don't put it in gear right away, it'll drop down back to normal in a few seconds. Has anybody experienced this and if so, what was your resolution? As always, thanks for your feedback, it is always helpful.
Old Oct 20, 2006 | 02:23 PM
eventer289's Avatar
eventer289
Default RE: engine rpms increase
You might try resetting your ECU (unplug the battery for 20 min and then reconnect). I have a friend who put an intake on an 04 GTO w/o disconnection the battery, and he had the same problem. I think the computer may have to just recalibrate for the increased air flow. Try it and let us know if it works or not.
Old Oct 20, 2006 | 02:43 PM
GodAmGT00's Avatar
GodAmGT00
Or, if that doesn't do anything, check your TPS connection/adjustment if you can..
Or, check your Throttle cable isn't catching on anything...
JT
Old Oct 20, 2006 | 02:44 PM
jbodak's Avatar
jbodak
Thanks for the suggestion. I'll try that this weekend. I am assuming that because there is a custom tune in the car's computer now (the stock tune is on my Excalibrator2 unit) the computer will reset to the custom tune. Am I assuming correctly? Can you tell I'm not a mechanic? I just want to make sure I don't screw up my car.
Old Oct 20, 2006 | 02:46 PM
jbodak's Avatar
jbodak
I'll check those two suggestions also, they seem simple enough. Thanks.
Old Oct 20, 2006 | 02:56 PM
boostedgt02's Avatar
boostedgt02
Also you might want to check the TPS voltage and set it to .98 just a suggestion.
Old Oct 23, 2006 | 11:38 AM
jbodak's Avatar
jbodak
Hey Eventer289!
On Saturday morning, I tried your suggestion of disconnecting the battery for 20 minutes so the computer can reset itself. I did some driving Saturday and a ton of driving yesterday doing a bunch of errands plus the drive into work this morning and so far, I haven't had that problem. So far it seems to have worked. Thanks again and thank you to everyone who responded.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
musnicki
Sep 23, 2015 07:11 AM
zanemoseley
Sep 6, 2015 12:58 PM
