Dead Spot
Old Oct 26, 2006 | 10:34 PM
Mrstang69's Avatar
Mrstang69
Default Dead Spot
Hello im new to the forum but not to the mustangs i had a 98 GT. But anyway to the point. I now have a 02 Mustang GT I just got like a week ago. When i start in first gear and really get on it then shift into sencond hard staying on it the engine starts out strong but it finds a dead spot for a second then contines up the rpm's. What do you think this could be? I was thinking some kind of sensor or something. I have a little knowledge on motors but mainly the old easy ones i dont understand to much of the computered ones. Please help
Jason
Old Oct 26, 2006 | 10:39 PM
wes ley n the G T's Avatar
wes ley n the G T
Default RE: Dead Spot
Well I'm not sure if this is it, but it could be just a cold engine. My car does that when its cold, but when it gets to regular temperature it doesnt.
Old Oct 26, 2006 | 10:50 PM
Mrstang69's Avatar
Mrstang69
I might of found the problem. I was reading on here about the traction control and people were saying with it on and racing it can cut off fuel. What do you think anyone?
Old Oct 26, 2006 | 11:07 PM
TOOT's Avatar
TOOT
When the traction control kicks in its diagram will light up in your dash (a green wheel). With your car being a 02 you should be able to disengage your traction control.
Old Oct 26, 2006 | 11:10 PM
andrewclark's Avatar
andrewclark
if you have TC on, and u spin ur tires, it cuts fuel and applys the brakes or something like that. take it off and u should have no problems. it also might be ur spark plugs, a bad plug can cause it to studder. u shouldnt be hard on ur car when it is cold
Old Oct 27, 2006 | 12:01 AM
Mrstang69's Avatar
Mrstang69
You shouldnt be hard on it when its cold outside or when the car itself is cold?
Old Oct 27, 2006 | 12:04 AM
Sxynerd's Avatar
Sxynerd
Pull your plugs... i bet money on one being bad...
Mike
Old Oct 27, 2006 | 12:06 AM
blueherd02gt's Avatar
blueherd02gt
+1
I was thinking misfire[&:]
ORIGINAL: sxynerd
Mike
Old Oct 27, 2006 | 12:07 AM
mvr's Avatar
mvr
mine does this when its cold... also grinds second a bit when cold... its normal
Old Oct 27, 2006 | 12:08 AM
andrewclark
ORIGINAL: Mrstang69
when the car is cold itself. if it is 100degress outside and ur car is cold, drive it normal, shift earlier. everthing is trying to warm up. ur trans, oil, all that stuff
