PI headswap complete!! dyno #'s.
finally got the heads in!! on her 6th run, she thumped out 301 to the wheels running hot and spit some coolant on the dyno. stock injectors and a MAF problem held her back as well. couldn't get a final torque reading, should be about 310-315 at 4200, but the dyno decided to stop reading my torque after i hit 305 on my 4th run. have yet to take her to the track, she's down right now with a broken crank pulley. hopefully she'll see some track time before september is up. gonna try to run her on radials, as street tires ain't gonna work.
RE: PI headswap complete!! dyno #'s.
Aren't pre 99 engines with the PI headswap supposed to develop more power than a 99 with the same bolt ons?
I would really hope with a set of cams I would be putting numbers down close to if not identical to your numbers, and that is with no head work. I also saw a 98 with a headswap and cams only post a 281 RWHP.
I have been promised 280 RWHP with my upcoming tune (from a untuned 263 RWHP and 12.1:1 A/F ratio)
Does the head work really do alot? In any case thouse are some nice numbers.
well lets see, i thought the heads were good for about 50rwhp, cams 20, and so say 225 along w/ ur other mods plus jus guestimating that 70 wuld put ya at 290 and sounds right to me?
a non pi (96-98) motor benefits from a PI head swap with increased compression. the PI heads have a smaller combustion chamber, wich on a pre 99 block increases compression to about 10.5 to 1, as the 99+ are 9.4 to 1.i broke 300 because the heads are ported with oversize valves, the cams of course and i have alot of bolt ons. upper intake, TB, L/T headers etc.... if i had thrown in a set of 24lb injectors and the motor been a bit cooler, she would have done at least 310. i intend to add those along with a few more items to up it, if i don't put a new shortblock in it first.
2000GT4.6, with a good set of cams, like VT stage II, most 99+ guys are hitting 280-290 on the stock heads. with full bolt ons and a good tune of course. the most i've ever seen in an N/A 2V displacing 4.6 cid is 334. and he runs 11.3's.
1 point increase in compression is only worth about 2% more power, so in your case about 6 rwhp. Your #'s are nice, that was dynojet #'s I assume? And 300 rwhp is attainable with stock PI heads, full bolt-ons and cams on any 4.6 GT.
Yeah, you can see my bolt on's below and without a proper tune, on a hot engine and a 110% humidity I averaged out 276 rwhp on the dynojet. Im sure if I have the heads ported and bigger valves put in with a set of new cans I will be well over three hunderd.
