coil packs
Old Nov 4, 2006 | 02:08 PM
handyandy's Avatar
handyandy
Default coil packs
Do you have to change these ever? I've never owned a car with coil packs.
Old Nov 4, 2006 | 04:39 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: coil packs
You only have to change one if it goes bad.
Old Nov 6, 2006 | 10:51 PM
handyandy's Avatar
handyandy
Do they go bad often? How can I tell if one is bad? Do they basically last forever? Can you get high performance coil packs or something like that for better performance?
Old Nov 6, 2006 | 10:58 PM
rjgstang's Avatar
rjgstang
granatelli motorsports sells high perf packs
Old Nov 6, 2006 | 11:05 PM
blstoff's Avatar
blstoff
ORIGINAL: rjgstang
+1 . here ya go . http://www.americanmuscle.com/sparkplugwires.html
Old Nov 6, 2006 | 11:07 PM
handyandy's Avatar
handyandy
500 dollars!!? wow. screw that. And is it exaggerating when it says 15 hp for N/A motor??
Old Nov 6, 2006 | 11:11 PM
rjgstang's Avatar
rjgstang
they tested them in 5.0 mag and thats what they got i dont remember if there was anything else to the motor than stock.
Old Nov 6, 2006 | 11:25 PM
blstoff's Avatar
blstoff
yeah , I hope I dont have to replace mine anytime soon , the stock coil packs probably cost alot too . I dont know about the 15hp . do you know which issue ? , I've had a subscription for years .
Old Nov 6, 2006 | 11:27 PM
rjgstang's Avatar
rjgstang
i just found it. it was october issue which means youve had it for at least 3 months if you have a subscription. page 164 and it was a s/c 02 gt the tested them on.
Old Nov 6, 2006 | 11:31 PM
99gtstang's Avatar
99gtstang
I have had 3 replaced
they go out and wont trip the COL sometimes...... i went through so much trouble finally took to a shop 150 per occurance
normally coil packs from dealer are around 40-65
so 500 is cheap for peromance coil packs
