Squeaking sound????
I have a squeaking sound that comes intermittently. It sounds like a slipping belt, but I just changed the Serpentine belt, and the sound is still there. It sounds like it is coming from the top of the engine, maybe the alternator? It also only seems to come around when it is warm out, or I have brought it higher in the RPMs. Anybody have any ideas?
It still does it with the new belt, and it is a different brand.
ORIGINAL: JPGT_00
do you have UDP's when I changed my pullys out I also got a gatorback belt, it sqealled like a pig, i put the stock belt back on and it went away.
ORIGINAL: eventer289
How much does it cost to replace an idler pulley, and is it something that I can change myself?
If that is it.
check to make sure all your pulleys are on tight, it may be your idler...but for some reason i keep thinkin water pump pulley...just check all pulleys...im sure turning one of them you should find the source of the squeeking when tightning down pulleys...good luck
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
